Thread: rear main seal
11-20-2008, 03:37 PM #1
rear main seal
i took the z into the shop to get rid of an oil leak and as the title says it was the rear main. 340 to fix it. that seems very good to me any others know of anyone with an ls1 that has had the same problem and what price they might have paid??????
11-20-2008, 04:57 PM #2
If you drop the trans, then pull the flywheel, the seal is in a cover that resembles the front timing cover. Should be fairly easy.
11-20-2008, 05:00 PM #3My Neighbors Hate Me!!!
- Jun 2006
- Ft. Lee, Virginia
Artic White- 2001 Chevy Camaro SS
340 seems a little expensive to change a seal that cost less than $10. I have a buddy who got his changed for a little over $100.
11-20-2008, 05:03 PM #4
It just depends on how much a shop charges. I believe its a 3.5 to 4 hour job. Most dealerships charge around 80 to 110 an hour. So it's pretty reasonable if you can't really do it yourself and you prefer to have a dealership do it.
11-20-2008, 05:33 PM #5Junior Member
- Sep 2007
- newmexico
lime green- 89 camaro lq4 th400 and
Its worth it i work in a ddealer ship in portale nm a po dunk town we charge $85 an hour and book pays 5.4 hours it's a good price plus you get a warranty from the dealer
11-20-2008, 05:33 PM #6
I changed my own,,,it was leaking as well.
It's not a hard job just labor intensive.
If a shop is only charging $340 I'd say thats cheap.
You have to pull the trans which entails dropping the Y-pipe out of the way etc..
If you have an auto the starter has to come off to access the torque converter bolts.
A 6 speed requires that all of the clutch goodies come off as well.
There is no real easy way around it unfortunately.
11-20-2008, 06:28 PM #7
i dont have the means to do all of that and it will be done tomorrow when i get off of work so i can pick it up pay and get home. i know it required dropping the tranny and getting to it which i have never done. but i got the shop to bring it back to and bitch at if happens again even though i dont expect it to anytime soon. i figured it was reasonable seeing as how vegas is a high dollar area with labor in general. and i didnt know if i should have expected it to be done within in a day not because of the job but the amount of business they had.
11-20-2008, 10:35 PM #8
Rear Main seal
By miguelr1988 in forum General HelpReplies: 1Last Post: 09-20-2012, 10:49 AM -
if i need a new rear main seal...
By wileyCoyote in forum General HelpReplies: 6Last Post: 01-13-2011, 07:24 AM -
rear main seal help
By Leeroyws6 in forum External EngineReplies: 5Last Post: 10-28-2010, 08:01 AM -
Question: Rear Main Seal
By SMWS6TA in forum General HelpReplies: 10Last Post: 08-01-2010, 06:07 AM -
Rear main seal?
By yellowv in forum General HelpReplies: 6Last Post: 08-19-2009, 02:49 AM
