Results 1 to 11 of 11
Thread: no speedometer
11-12-2010, 03:45 PM #1
no speedometer
my 98 z28 has no speedometer therefor wont shift. I have replaced the vss with a brand new one...it is getting voltage from pcm. is the anything else that could be wrong.
speedo worked great until tranny rebuild. car hasnt been anywhere since.PLEASE HELP
11-12-2010, 05:12 PM #2Senior Member
- Apr 2008
- Madison, WI
sounds like maybe they forgot to put the reluctor rotor ring back on the output shaft.
11-13-2010, 06:51 AM #3
pull the tail housing and see if it's in there.
11-13-2010, 08:53 AM #4
i will try that...that has to be about the only thing that i have not done at this point....thanks for the input....if anyone eles thinks of a possible problem chime in.
11-17-2010, 04:41 PM #5Junior Member
- Nov 2010
- Texas
Red- 2002 Camaro SS
You don't have to pull the housing - just remove the VSS and you will be able to feel the reluctor ring with your finger. If it is there then use a screwdriver and see if it is tight-just don't force it if it is.
11-18-2010, 02:17 PM #6
11-18-2010, 03:17 PM #7Junior Member
- Nov 2010
- Texas
Red- 2002 Camaro SS
The reluctor ring should be tight -I think it is a press fit.If it feels loose when you check it with your finger or a screwdriver something is wrong. Can you feel it with your finger thru the hole ? What do you mean kinda loose ? It has to be solid on the shaft .The reason I say this is I just did all this stuff this week with the help of the above guys.Also if it is tight did you ohm the sensor ?
11-19-2010, 04:16 PM #8
i got sent out of town for work,but i have a guy checking it out for me. yes the sensor was checked. as far as i know all electronics are good. ill kept you posted when i find out myself.
Phil
12-20-2010, 04:50 PM #9
that was the problem speedo worked fine up to about 110 thats when it stopped shifting.shifted into 2nd fine but never tried to shift out of second. seems like a shift solenoid to me. is that what everyone else thinks
12-21-2010, 02:13 PM #10
12-22-2010, 04:50 PM #11
Improving Pontiac Speedometer Accuracy - Speedometer Super-T
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 02-27-2012, 09:10 PM -
110 MPH speedometer on Z28
By Dave-TransAm in forum Camaro / SSReplies: 13Last Post: 03-24-2010, 07:39 PM -
Speedometer
By Dave-TransAm in forum Firebird / WS6Replies: 2Last Post: 03-12-2010, 09:53 PM -
Speedometer WAY off need some help!
By ziominix in forum General HelpReplies: 21Last Post: 05-13-2009, 06:13 AM -
speedometer help
By shortbed454 in forum Stereo and ElectronicsReplies: 0Last Post: 01-13-2006, 10:25 AM
