Results 1 to 20 of 22
    West Virginia
    Satin Silver / RED
    02 Acura RSX/93 Transam
    Speedometer WAY off need some help!
    I've had my TA 2 days now and I'm trying to get stuff lined out on fixing the few issues it has. My primary concern is the speedo, it reads 31mph when I'm actually traveling about 70mph. The car has 4.11's in a moser 9". The previous owner was told it should be able to be programmed out, however my father, who owns a garage, feels that as far off as it is it must need a mechanical correction as well.
    Any ideas??
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Any tuner shop or handheld programmer will work. Not sure if the dealer could do it.
    West Virginia
    Satin Silver / RED
    I thought only the later model years with the OBDII could be flashed to fix the speedo.
    Feb 2006
    Orange County, NY
    always dirty
    I just noticed it was a 93. I am not sure if it is electrical or not.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    electric speedo. have to have the chip flashed. 1993 was the last year for remove able chips.
    West Virginia
    Satin Silver / RED
    Ok well I found out today the car was converted to OBDII so now it should be a simple plug in and reflash issue right?
    TEXAS... U mad?
    Black / Stryker Blue
    2K WS.6/ 2K9 G8GT
    should be, any resolve to this yet??
    West Virginia
    Satin Silver / RED
    Well I'm not sure what all's going on. Went to plug up to it yesterday, and its an OBDI connector but has communication issues when 93 year is chosen, but works smoothly when 95 is chosen. This was just a diagnostics computer, no two way communication. No codes thrown though! So I don't think a 93 programmer is going to help. I'm going to let some of the techs at work take a look at it this weekend. (I sell cars at a GM dealership and get along pretty well with several of the techs.)
    Hopefully I'll know more Saturday.
    West Virginia
    Satin Silver / RED
    UPDATE:
    Never got the speedo fixed. I had a performance shop tell me I need a new gm speedo gear. GM service dept pulls up only one being available, so it must be whats already in the car. Had a tech suggest maybe its the vehicle speed sensor buffer?? Any other ideas? I'd buy a tuner and try to correct, but considering how off it is, I don't know if thats possible. If its reading 31, and I'm actually traveling 70, is a tuner going to fix that?
    Member DaddySS's Avatar
    Bergen Co. NJ
    2000 Camaro SS Conv.
    When the tuner plugs in, he will just select the gearing so it should be easy. Find a tuner in your area and let them fix it. Most have a low price for a simple speedo correction.
    That guy thearborbarber's Avatar
    SoDak
    White over Red
    1991 Suburban
    1993 is last year of the "mechanical" transmissions for the camera. You will need a new speedo gear to correct your speedometer. The PCM does not control any functions of the transmission. This page should have all the info you need;
    http://www.tciauto.com/Products/Tech...eedo_gears.asp
    Member qwk93ta's Avatar
    Fairfield, Ohio
    00 WS6
    Quote Originally Posted by thearborbarber View Post
    No he won't, I had the car converted to mass air....he just needs to have a speed shop change the tune for the gears in the 9".
    SoDak
    White over Red
    1991 Suburban
    Quote Originally Posted by qwk93ta View Post
    That is true for every year of 4th gen but 1993. It still had the 700r4 (AKA 4l60) not the electronic version 4L60E on the 94 and newer f bodies. The speedo was still mechanical and driven from a gear off the tranny. The tranny got its throttle position information via a TV cable (old school kick down cable) off the throttle body.
    http://en.wikipedia.org/wiki/Fourth-...evrolet_Camaro
    http://www.ls1lt1.com/forum/showthread.php?t=25245
    The easiest way to tell which transmission is there is to look on the side of the throttle body where the throttle cable attaches. If there is a second cable that traces back to the tranny then it's a 700r4, if there is only the throttle cable then it's a 4l60e.
    West Virginia
    Satin Silver / RED
    Every shop I've called is telling me that won't do it.
    West Virginia
    Satin Silver / RED
    Flashing it that is. If it would I should just be able to buy a handheld programmer and fix it, but cincy speed says its the speedo gear issue.
    Junior Member Snakes4's Avatar
    May 2008
    Goldsboro, NC
    96 TA WS6 with LS1/Trans
    Hey, just get your ECM reprogrammed for the 411 gears and any tire size ratio differences other than stock. You might as well do some other mods and then get it programmed so you only do it once.
    Fairfield, Ohio
    00 WS6
    I replaced the 700r4 with a 4l60e and then had an M6 installed, and I had a 94 or 95 computer and harness put in the car.....so it's really not a 93 any longer.
    SoDak
    White over Red
    1991 Suburban
    That would have been some useful info from the get go.
    Fairfield, Ohio
    00 WS6
    The new owner knows all about it.
    Member mild2wild's Avatar
    Apr 2009
    E of Rochester NY
    Orange/Black
    1999 Camaro SS
    Just curious, did you get these issues worked out yet??
    I'm a CHICK with a gun and an LS1, nuff said...
    1999 CAMARO SS #81 of 4829
    LS6 intake * 3.73's * Borla catback * L/T Headers
    ZO6 18's * MSD/NGK * SLP Lid/Bellows * KYB Adjustables
    Summit Racing Springs * Fresh paint/interior in 08
  1. Improving Pontiac Speedometer Accuracy - Speedometer Super-T
    Last Post: 02-27-2012, 09:10 PM
  2. speedometer off
    By wvbrett in forum Firebird / WS6
    Last Post: 06-06-2011, 09:30 AM
  3. 110 MPH speedometer on Z28
    By Dave-TransAm in forum Camaro / SS
    Last Post: 03-24-2010, 07:39 PM
  4. Speedometer
    By Dave-TransAm in forum Firebird / WS6
    Last Post: 03-12-2010, 09:53 PM
  5. speedometer help
    By shortbed454 in forum Stereo and Electronics
    Last Post: 01-13-2006, 10:25 AM
