Thread: transmission slipping
11-05-2010, 08:07 AM #1Junior Member
- Nov 2010
- baytown, tx.
sebring silver,silver- 2002 z28,2010 camaro ss
What cause tranny to slip when in high gear, had tranny rebuilt, same results.2002 z28
11-05-2010, 08:15 AM #2Junior Member
- Nov 2010
- Saudi Arabia
Red- Lumina SS
Sounds familiar, got the same problem with mine after a rebuild, but suspect the garage to be the problem. An auto transmission uses solenoids to act on the clutches inside the transmission. So if the Cluch plates are worn or the solenoids are knackered then it will slip. Apparently I have an inherent electrical problem with mine that has cause this failure. Will find out the cause tomorrow hopefully. I would suggest taking it to a specialist.
11-05-2010, 08:17 AM #3Member
- Staten Island, NY
2007 Cadillac Escalade- 98 Camaro SS, 09 G8 GT
Too much POWA....not enough oil, not rebuilt correctly...etc. Your slipping in 4th? When is it slipping (WOT, normal driving)? My trans slips terribly in 3rd when at WOT (hitting the 6700 rev limiter in 3rd at 65 mph) but when driving normally it's fine. We need more info.
1998 Sebring Silver Camaro SS Convertible
Cammed, Geared, Stalled and soon to be blown via F1-C
2009 Stryker Blue Pontiac G8 GT
Kook's 1 7/8's LTH's and catted X, Pypes A/B, Vararam, Tune
2007 Black Raven Cadillac Escalade
Vararam, Leveling Kit, 33's
11-05-2010, 08:23 AM #4Junior Member
- Nov 2010
- baytown, tx.
trans slipping
yes it's better then new when driving normal, slips when 60 or more.
11-08-2010, 04:32 AM #5
it could be a number of things.probably want built right.mine did the same thing after a "rebuild" turned out to be bad clutch clearance.3-4 clutches.
transmission slipping II
By 79Firebird_99TA in forum Automatic TransmissionReplies: 24Last Post: 12-30-2010, 07:08 PM -
Transmission slipping now engine wont run...
By 99formulals1 in forum General HelpReplies: 12Last Post: 04-07-2009, 06:04 PM -
Help: Transmission slipping
By chaosinfinite in forum Automatic TransmissionReplies: 0Last Post: 03-07-2009, 04:32 PM -
Transmission Slipping at 2500RPM
By redfiress08 in forum Manual TransmissionReplies: 1Last Post: 11-04-2007, 04:49 PM -
Transmission Slipping - Code P1870
By quaijai in forum Automatic TransmissionReplies: 3Last Post: 09-05-2007, 12:04 PM
