Results 1 to 13 of 13
    Skint Back 99formulals1's Avatar
    Jan 2008
    Louisiana
    blue
    99 firebird formula 06GTO
    Transmission slipping now engine wont run...
    well today i was driving to town and all of a sudden the tranny went to 3rd, and would not shift into od. while i was driving around town it seemed to stall up alot more than normal (I have a 3600 stall) but still drove, then when i was leaving town from a red light it shifted to 2nd then the rpms went up. and nothing, i pulled over to look under the hood and under the car, when i went to leave it started back fireing when i gave it gass, now it wont run at all. it seems as if the tranny died the engine would still run fine, are theese problems connected or do i have two problems that occured at the same time. If you have any ideals please chime in i dont even know where to start.
    TJEA Retirement Home Dr.Crash's Avatar
    Feb 2006
    U. S And A Greatest country in all of world
    Stock
    2002 Camaro
    i would start with the engine first. does the engine turn over? i know that people who have had alt problems have noticed their a4's have started to act up as well as their engines. Like i said i would start with the engine first. good luck
    Jan 2008
    Louisiana
    blue
    Quote Originally Posted by Dr.Crash View Post
    yes the engine turns over, i checked the fuel pressure and there is none, the fuel pump is out, i changed the filter and the relay, still nothing, looks like ill be changing that. just seems funny for the tranny to act like that right before it quit running to me.
    Feb 2006
    Stock
    2002 Camaro
    like i said it could be a alt problem that caused the pump to go out and the tranny to act up. start with the pump.
    Jan 2008
    Louisiana
    blue
    thanks for the info, i'll change the pump and have the alt checked when i tear it down i got heads on the way but i want to get it back running before i get into that.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    I would check for power and ground to the pump using a test light while cranking the engine before just throwing a pump at it. Maybe even check for codes
    Jan 2008
    Louisiana
    blue
    is it possible to get to the wires or connections without dropping the tank? or will i have to lower the tank to be able to test for power and ground?
    Feb 2006
    Stock
    2002 Camaro
    http://www.ls1tech.com/forums/fuelin...p-install.html
    here what some people do. i am most likely going to as well
    Madison, WI
    2001 Silverado Z71
    yeah if you can get to the fuel tank harness where it plugs into the electrical passthrough forward of the rear axle. Its the gray and black wires.
    Jan 2008
    Louisiana
    blue
    thanks for posting that man, thats exactly what im gona do as soon as the pump comes in, im sure its the pump now i finally got it to come on and im only getting 5psi, just waiting on a new pump.
    Feb 2006
    Stock
    2002 Camaro
    no prob, good luck
    Jan 2008
    Louisiana
    blue
    now what
    I changed the fuel pump today, 60 psi, all good there, engine runs again, took it to the road and i could tell it was slipping in od, it wouldnt go into lock up.
    After the trans got to 150 deg. it quit pulling all together, which would make me believe that the tranny is gone, but when the transmission quit pulling the engine started cutting out.
    I wasnt on the revlimiter or anything about 4k it would just bogg down, then i peddled it and the engine came back to life but the transmission wouldnt do anything, now what do i need to look at??
    Feb 2006
    Stock
    2002 Camaro
    maybe its some sort of a short?
  1. transmission slipping II
    By 79Firebird_99TA in forum Automatic Transmission
    Last Post: 12-30-2010, 08:08 PM
  2. transmission slipping
    By jwynn in forum Automatic Transmission
    Last Post: 11-08-2010, 05:32 AM
  3. Help: Transmission slipping
    By chaosinfinite in forum Automatic Transmission
    Last Post: 03-07-2009, 05:32 PM
  4. Transmission Slipping at 2500RPM
    By redfiress08 in forum Manual Transmission
    Last Post: 11-04-2007, 05:49 PM
  5. Transmission Slipping - Code P1870
    By quaijai in forum Automatic Transmission
    Last Post: 09-05-2007, 01:04 PM
