    Pinole, Ca
    Black Cherry
    1996 Impala SS
    Transmission Slipping - Code P1870
    Can anyone help? I have a 96 Impala SS that has a code of P1870 indicating the transmission is slipping. Does anyone know how I can repair the trans without replacing the transmission? Any help would be great. Thanks
    Senior Member
    Jacksonville, FL
    Saw your other post, I'd PM the guy too since it's from last year. In the meantime I found this for the 5.7: www.ls2.com/boggs/a4/DTC%20P1870%205.8.htm
    Pinole, Ca
    Black Cherry
    1996 Impala SS
    2001NBMZ28,
    Thank you for your reply. I will look at the site and see if I can follow instructions on how to check trans.
    IOWA
    WHITE
    1999 CAMARO Z-28
    A TFP Valve Position Switch malfunction could set DTC P1870.
    The following mechanical conditions could set DTC P1870:
    A mechanical failure of the shift solenoid valves
    A mechanical failure of the TCC Solenoid Valve
    A mechanical failure of the TCC PWM Solenoid Valve
    Internal transmission failures may set a DTC P1870.
    An engine, misfire may erroneously set a DTC P1870.
    Ensure that the final drive ratio matches the PCM's calibration.
    A PRNDL DTC may falsely set DTC P1870.
  1. transmission slipping
    By jwynn in forum Automatic Transmission
    Last Post: 11-08-2010, 04:32 AM
  2. Help: Transmission slipping
    By chaosinfinite in forum Automatic Transmission
    Last Post: 03-07-2009, 04:32 PM
  3. using tighter stall and have a p1870 code?
    By Frankthetank in forum Automatic Transmission
    Last Post: 08-25-2008, 12:47 PM
  4. trouble code p1870
    By pete99firebird in forum Drivetrain
    Last Post: 07-21-2008, 12:43 PM
  5. Code P1870 & TCC Slip Table
    By tblu92 in forum Computer & Tuning
    Last Post: 05-22-2007, 05:18 PM
