Results 1 to 11 of 11
Thread: Squeaking....
09-23-2010, 04:39 PM #1
Squeaking....
Okay i have a 98 firebird and i was told these cars do NOT have struts? Well every damm time i turn or go over a bump BOTH shocks or whatever it is squeaks.... Since there are no struts then what the heck is causing the squeaking!? Im 16 so ya know... cut me some slack. Im learning up on this stuff
09-23-2010, 05:52 PM #2
I assume you are talking about the front end? If so, this is what you have back there:
The spring assembly is integral to the shock and is therefore a "strut". As far as the squeek goes, it could be a dried out bushing or worn suspension parts.
09-23-2010, 08:11 PM #3
Its probably your upper A-arm joints. When they dry out, you will hear a god awful squeak over bumps and such.
3" MagnaFlow CatBack w/Corsa (clone)Tips, Lloyds Custom Floor Mats, SLP Lid, Pro 5.0 W/ Lou's SS, 7.5" Eaton Locker w/3.73, KYB AGX, BMR LCA's, FRA, SSE, 5% Tint, 18x9 C5 Rims w/Falken 452
09-24-2010, 07:20 AM #4
could be the sway bar bushings, the only way to find out is to get underneath and have someone rock the front end up and down while you listen for it
09-24-2010, 12:08 PM #5
thanks guys. this car here is my most def project car. soooo many problems with it lol. ima get it fixed soon.
04-06-2011, 08:59 AM #6
Annoying squeak in the front end
I was searching around for someone with the same problem as mine and found this thread. I've narrowed mine down to the front right - it's a squeak that i can reproduce by bouncing the front of the car up & down by hand. I know on the older cars, they had grease fittings everywhere but as far as I can tell -nothing to grease on these ,, is that right ?? If it is the A-arms, what is the resolve for that?? --any other part that could be suspect ?
04-06-2011, 09:11 AM #7Member
- Jan 2010
- culver city, Ca.
Blackened fire chicken- 2000 Pontiac Trans Am WS6
you have front struts and rear shocks...whoever told you that you dont have front struts is a moron...no offense to you of course
most my suspension parts are aftermarket and have grease fittings, so whenever they start squeeking, i just grease them up and itll go away for about half a year until i have to grease them again...plus those stock rubber bushings in the rear control arms can get really bad too...our cars are getting up there in age, so the stock rubber bushings are gonna go sooner or later...if you wanna play, you gotta pay
04-06-2011, 09:54 AM #8
Thanks for getting back to me so soon. That wasn't me who didn't know about the struts -just sayin'. I realize a new aftermarket suspension would be best BUT, for now I'd just like to find the squeaking part and maybe spray lube it up until i can replace it all. Maybe there's a part ( A-arm was mentioned) that usually goes up ?? It's an '02 w/ 90,000 miles. Everything 'looks' ok visually. Are bushings hard to do in a driveway on jackstands ??
04-06-2011, 10:34 AM #9Senior Member
- May 2009
- college station, tx
sold: 1999 firebird- 1998 Trans Am
white lithium grease in a shaker can will fix that right up if you dont feel like changing a bushing
04-06-2011, 01:39 PM #10
04-06-2011, 01:56 PM #11Member
- Jan 2010
- culver city, Ca.
nope... ive done everything with a jack and stands...i wouldnt waste your time and money replacing the stock bushings with stock bushings again, either go with poly bushings or just save up some dough and beef up the suspension. Spray it with that lithium grease for now, like justin said, and save until you can afford to fix it the right way with the better parts. also, remember you have to "load the suspension" before tightening things down to avoid bushings from binding...learn from my mistakes!
haha
squeaking front end
By purplebat66 in forum Firebird / WS6Replies: 6Last Post: 09-26-2010, 05:51 PM -
Squeaking noise
By 35th-ANV-SS in forum General HelpReplies: 17Last Post: 07-11-2010, 09:48 PM -
'squeaking’ going on in my rear bad
By MotorDogStar in forum Firebird / WS6Replies: 8Last Post: 07-01-2009, 11:09 PM -
Help: Squeaking Noise
By Insert in forum General HelpReplies: 6Last Post: 06-01-2008, 10:04 AM -
Rear end squeaking
By Gary in forum Suspension and HandlingReplies: 5Last Post: 02-01-2008, 05:23 AM
