Thread: Squeaking Noise
05-31-2008, 05:31 PM #1Pony Killer
- Apr 2008
- Mississauga, Ontario, Canada
Black- 2002 Camaro SS M6
Squeaking Noise
I have a squeaking noise coming from the back of my camaro. somewhere from the truck area i think. the noise is only where when driving over bumps.
anybody know what i am talking about? or how to get rid of it? it only happens sometimes.
thanks in advance.
05-31-2008, 06:31 PM #2
I had something like that. Back it up some rhino ramps and secure the front wheels. Then try pushing up on the body from underneath. Mine was very intermittent and turned out to be a thin piece of metal below the gas tank area. Bent it with my finger slightly and hasn't occurred since.
05-31-2008, 07:01 PM #3
Squirt some WD-40 on all rubber bushings . Driver side or pass.side ?
I had same problem after some rear end work .
05-31-2008, 07:25 PM #4Mr. P
- Jul 2007
- Augusta, Georgia
Bright Red- 99 Z28 M6, 03 Gixxer 1000
WD-40 could do it, it also could be worn out spring isolators/bushings or whatever you want to call to rubber boots that are on top of the rear springs. They get worn out and can start to squeak.
05-31-2008, 09:45 PM #5
06-01-2008, 09:55 AM #6Pony Killer
- Apr 2008
but the sound is interior... you can't hear it from outside... its not loud at all, and as stated above, it is very intermittent. sounds like something loose inside the rear of the car.
btw. i've also had the same problem on my previous f body (95 firebird) and i never found the problem before i sold it. i doubt it affect my performance, its just annoying as hell.
but thanks, i shall check the rear springs.
06-01-2008, 10:04 AM #7Junior Member
- Ohio
Bright Red, Victory Red- 00 Camaro SS, 07 Corvette
If the noise is coming from the right rear area you may want to check to see if the spare tire is loose or just making the squeaking noise.
Help: odd squeaking noise
By stern2192 in forum General HelpReplies: 3Last Post: 05-03-2013, 09:52 AM -
Squeaking noise
By 35th-ANV-SS in forum General HelpReplies: 17Last Post: 07-11-2010, 09:48 PM -
OBNOXIOUS squeaking noise
By tep98ws6 in forum General HelpReplies: 14Last Post: 09-09-2009, 10:02 AM -
Squeaking noise
By garver in forum Firebird / WS6Replies: 4Last Post: 10-23-2007, 01:10 PM -
squeaking noise in clutch pedal
By riverca in forum Manual TransmissionReplies: 0Last Post: 01-22-2006, 09:54 AM
