    Feb 2012
    Ohio
    2001 z28,1971 Monte Carlo
    odd squeaking noise
    Hey guys I cant figure this out for the life of me. My 01Z is making a squeaking noise from either the front drivers or rear tire. It makes the noise when i am driving and it seems like every revolution the tire makes. Im thinking its the break pad, but not positive. I was also considering i might need an alignment. Any help with my problem would be appreciated!
    You can usually determine if it is the brakes making the noise by applying light pedal pressure while driving. If the noise changes, then it is likely an issue with the brakes. On our cars, the caliper pins are notorious for seizing up when not properly maintained. If you have never serviced them, its not a bad idea to pull them apart, clean the pins, and then lube them with synthetic caliper grease.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Agreed. Caliper slide pins.
    Feb 2012
    Ohio
    Thanks for the input guys! Looks like i now have something to do this weekend now
  1. Squeaking noise
    By 35th-ANV-SS in forum General Help
    Last Post: 07-11-2010, 09:48 PM
  2. OBNOXIOUS squeaking noise
    By tep98ws6 in forum General Help
    Last Post: 09-09-2009, 10:02 AM
  3. Help: Squeaking Noise
    By Insert in forum General Help
    Last Post: 06-01-2008, 10:04 AM
  4. Squeaking noise
    By garver in forum Firebird / WS6
    Last Post: 10-23-2007, 01:10 PM
  5. squeaking noise in clutch pedal
    By riverca in forum Manual Transmission
    Last Post: 01-22-2006, 09:54 AM
