Thread: Rear end squeaking
01-27-2008, 09:58 AM #1
- May 2007
- Spring Tx
Silver- 1999 Corvette
Rear end squeaking
Anyone out there help me with this? It is an up and down squeak. I have replaced the shocks, swaybar connectors, put anti seeze on all the rubber components, driven the car without the sway bar and the rear end still squeaks. I'm thinking maybe the rubber where the rear shock ties into the frame.
01-27-2008, 12:17 PM #2
- Jun 2006
- Arnaudville, LA
Bright Rally Red- 01 Camaro SS M6
That is what happened to me after installing my Adj-TA and setting it at -3 degrees. The rubber bushings between the shock post and the frame get worn and before you know it the shock post is rubbing the frame and sounds like a straw going up and down in a McDonalds cup...will drive you f'n nuts! I think jegs sells new shock bushings/rubber.
01-27-2008, 12:18 PM #3
When the rear end of my car squeaks i just spray some wd 40 on all of the moving and rubber parts and that helps me until the undercarriage gets wet.
01-27-2008, 12:28 PM #4
- May 2007
- Spring Tx
Squeaking
Thanks to both of you.
Gary
01-28-2008, 05:31 PM #5
I have heard that subframe connectors stop a lot of squeaks and it improves handling so you might want to try that...
EDIT: Not sure if they are made for the corvette though.
I'd either PM or better yet call Sam Strano. He knows a lot about suspension.
02-01-2008, 05:23 AM #6
Help: Squeaking....
By flybird in forum Firebird / WS6Replies: 10Last Post: 04-06-2011, 01:56 PM -
'squeaking’ going on in my rear bad
By MotorDogStar in forum Firebird / WS6Replies: 8Last Post: 07-01-2009, 11:09 PM -
Squeaking Sound
By Fade2Black in forum General HelpReplies: 8Last Post: 11-14-2007, 01:42 PM -
Squeaking noise
By garver in forum Firebird / WS6Replies: 4Last Post: 10-23-2007, 01:10 PM -
Squeaking sound?
By bgable in forum General HelpReplies: 3Last Post: 07-05-2007, 09:44 AM
