Results 1 to 2 of 2
09-17-2010, 07:59 PM #1Junior Member
- Aug 2010
- Clarksville, Ar
various- 1986 Turbo 944
Valve seat and double spring questions
I have begun to install my new cam and valve train. The instructions say to run the engine for the first 30mins-1hr with just the outside set of the valve springs.
Is there any special way to get the inner springs out or is it just pushing them?
also when pulling apart the head to put the testing springs on cylinder one, I realized that some of the valve seats have surface rust on them. They were reseated when I purchased the heads last year, which they sat there for 6 months before I bought them, do I need them to be redone or is this ok?
09-18-2010, 02:47 AM #2
as far as the break-in, that write up is for flat tappet lifters. On our roller lifters, you will be OK to install both springs. I'd clean up the surface rust with a scotch brite pad, or a soft wire wheel on a drill.
Question: Valve Spring Kit
By badboy10 in forum Internal EngineReplies: 3Last Post: 02-19-2014, 08:01 PM -
Question: GM discontinued lower spring seat?
By 98TransAmWs-6 in forum Suspension and HandlingReplies: 2Last Post: 11-18-2011, 08:02 AM -
JEGS stud mount valve spr. compresor vs. Speeds valve spring
By JehalinTA in forum Internal EngineReplies: 0Last Post: 05-30-2011, 05:16 AM -
valve spring help
By iluvls1rails in forum Internal EngineReplies: 3Last Post: 02-01-2010, 10:27 AM -
Double Valve Springs With Locks and Retainers
By ls1camino in forum Parts Wanted / TradeReplies: 0Last Post: 12-06-2008, 06:20 PM
