Thread: fuel lines
    Mustang Eater Ls_won's Avatar
    Feb 2010
    Springfield, Missouri, United
    Maroon
    2000 z28 6 speed
    Exclamation fuel lines
    when i was changing my fuel filter this week, it was so jammed on there that i pinched the little "L" shaped fuel line from the fuel filter, is it possible to replace it with a brake line or something, i know its high pressure, but space is tight down there. Just wondering on what i can do to fix it, or if some one knows that lines part number ill just buy a new one from chevy, i just dont want any brakes or leaks!
    2001 B4C Totaled 4/25/11
    2000 Z28 M6 Cammed N' Slammed (SVT KLR)
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by Ls_won View Post
    As for brake line.. Brake line handles far more psi than fuel line and you could use it if it's the right dia. However, you'd probably have to also use some rubber fuel line and a bunch of clamps to secure it to the filter.. If it where myself, I would do as you suggested, and replace the line with the proper replacement honesty.. More work but a for sure fix.. Quick disconnect is nice to have in my honest oppy.. If you're talking about the threaded portion and using a brake line with it's threaded fitting then no, brake threads and fuel line threads are not the same..
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Are you talking about the L shaped hard line from the filter to the T fitting like in this picture? You should be able to buy it or find someone to make one.
    Member DaddySS's Avatar
    Bergen Co. NJ
    2000 Camaro SS Conv.
    the parts manual shows the front lines as a group - 10424769. If you are just talking about th short line pictured above it should be easy for a good parts place to make it for you.
  1. Question: C5 Vette fuel lines
    By kingls1 in forum General Help
    Last Post: 08-05-2012, 05:47 PM
  2. Question: Fuel lines
    Last Post: 07-21-2012, 05:56 AM
  3. Question: fuel lines
    By pewter Z28 in forum General Help
    Last Post: 08-16-2010, 05:24 PM
  4. Question: fuel lines
    By 2000dreambird in forum External Engine
    Last Post: 05-21-2010, 08:20 AM
  5. Help: air and fuel lines
    By third_shift|studios in forum General Help
    Last Post: 03-14-2009, 06:54 AM
