Thread: fuel lines
    Member 2000dreambird's Avatar
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    fuel lines
    when i do my intake this weekend how do i get the fuel lines off,do i need a disconnect tool,do i need to bleed pressure????
    Pittsburgh
    2008 Hummer H3
    A disconnect tool would be handy but it can be done with picks or small regular (strait) screw driver. Yup, good idea to release the rail presure @ the schroeder(sp) valve first.. Then rubber cap the open ends of the fuel lines and rail in/out ports to prevent dirt/debris from entering the fuel system...
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    You don't need to disconnect the fuel lines. You can pop the injector/fuel rail off the intake and lay it over to the drivers side with the fuel lines connected
    Pittsburgh
    2008 Hummer H3
    Thumbs up
    Too bad you can't do that on the 6.. ugh pita..
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    while this is the way i did it...i dislike this way...just due to the fact that popping them back on and off is a pain and not the easiest ..
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    If you have the tool, It is much easier to get them out of the way. I did it the way Cutlass described the first time and it seems much easier to get them out of the way.
    Either way will work though.
  1. Question: C5 Vette fuel lines
    By kingls1 in forum General Help
    Last Post: 08-05-2012, 05:47 PM
  2. Question: Fuel lines
    Last Post: 07-21-2012, 05:56 AM
  3. fuel lines
    By Ls_won in forum General Help
    Last Post: 09-03-2010, 06:02 PM
  4. Question: fuel lines
    By pewter Z28 in forum General Help
    Last Post: 08-16-2010, 05:24 PM
  5. Help: air and fuel lines
    By third_shift|studios in forum General Help
    Last Post: 03-14-2009, 06:54 AM
