Results 1 to 20 of 35
    Question air and fuel lines
    Part 1: Air lines...this is a continuation from an older thread. I had noticed a broken air line (A) and it never threw a code, so i followed the line (B first pic to B second pic) and put a cap on it at that joice-is that ok?
    Part 2: i'm trying to attach 6AN braided line to the main hard fuel line(A)-but i don't know what i need to do it. Also-is it true that the Evap line (B) can be capped off b/c it's only for emissions? There is currently fuel in that line, is it ok to cap it where it is?
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    I believe you did part 1 correctly.
    Part 2 however looks like the fuel return line, not the evap purge line. Especially since it has fuel in it.
    the car is a 2000...is it possible i had 2 fuel lines? Line B DID have an evap regulator cap on it for sure.
    Part 1 is your secondary air injection system. After startup, the electric air pump in front of your left front tire pushes air into the exhaust manifolds through the air valve. The line "A" is the vacuum supply to the air valve from the electric solenoid. Surprised it hasn't thrown a code.
    Cool, so Part 1 is safe-anyone have any thoughts on part 2?
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Those lines need to be kept. 1 of them is the fuel return line and I think the other is a vent to the charcoal box. I would keep them if you ever plan on driving it on the street. Might have fuel issues otherwise
    Madison, WI
    2001 Silverado Z71
    Ok I just went and looked at mine. TSS you are correct. B in photo 2 is the evap purge line. You should be able to plug it but it might throw a SES light for a EVAP purge solenoid problem.
    conflicting info
    cutlass, are you talking about "issue 1, photo 2" or "issue 2?"
    Madison, WI
    2001 Silverado Z71
    oops my bad issue 2 which is actually photo 3. B in photo 3 is the evap purge line. You should be able to plug it but it might throw a SES light for a EVAP purge solenoid problem.
    THanks for clearifying. I was told that by an Ls1 mechanic too so I'm hoping the code is all that needs done.
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    id keep the evap because it helps regulate fuel tank pressure ..it would be a good thing to keep around since increase pressure = increase heat...it doesnt rob power or anything so i would keep it..piece of mind really
    Beaver Dam KY
    79 T/A -91 Firebird
    Yep. Evap is usually kept unless your running a fuel cell.
    ok thanks guys! more or less worried b/c i'm running braided lines all over the engine now and was hoping i could cut some corners. thnks!
    Shepherd, Michigan
    98' trans am
    cutting corners...you bastard
    considering each line costs about $20 to run, yes i am
    Shepherd, Michigan
    98' trans am
    you know it costs to play
    since when did you graduate Mod School and become the professor?
    Shepherd, Michigan
    98' trans am
    since i realized that cutting corners will come back to haunt you
    Shepherd, Michigan
    98' trans am
    i am not giving you a hard time jaison..i was just saying ..
    it's cool man! I mean, only what, 5/6 months ago you were still asking "how should i mod my car" then in the last 7 days you post all kinda techy shit, what with that PM and all too! Good for you
  1. Question: C5 Vette fuel lines
    By kingls1 in forum General Help
    Last Post: 08-05-2012, 05:47 PM
  2. Question: Fuel lines
    Last Post: 07-21-2012, 05:56 AM
  3. fuel lines
    By Ls_won in forum General Help
    Last Post: 09-03-2010, 06:02 PM
  4. Question: fuel lines
    By pewter Z28 in forum General Help
    Last Post: 08-16-2010, 05:24 PM
  5. Question: fuel lines
    By 2000dreambird in forum External Engine
    Last Post: 05-21-2010, 08:20 AM
