Thread: rear end link bushing install
08-31-2010, 04:46 PM #1Junior Member
- Oct 2009
- ohio
red hot- 2005 gto
hey,
what is the best way to install the 1 piece energy suspension bushings for the rear swaybar endlinks.
i have tried to twist them in place , pushed on them and my fingers are killing me.
i searched but could not find anything , does anyone know of any threads or has anyone done this ?
any help would be great thanks.
08-31-2010, 06:29 PM #2Member
- Jan 2008
- West Michigan
Never did the one piece, but my guess would be to press them in with a vice. Try soaking them in HOT soapy water first and put them in the vice and get them started most of the way. Then put a larger socket (18mm - 20 mm or so) as a receiver and a smaller socket (10mm?) as a push plate and press them enough to seat them. Dry them well and lube as directed in the package. Make sure the interior faces of the end link are cleaned and free of debris before pressing in the new bushes. Use some scotch brite pads to clean them.
09-01-2010, 04:02 PM #3Junior Member
- Oct 2009
- ohio
red hot- 2005 gto
PartsGedder,
Thank you very much
I used my woodworking vise and they went right in.
thanks again.
tim
09-01-2010, 05:14 PM #4Member
- Jan 2008
- West Michigan
Tim,
Glad I could help.Dan Morris
Poly TQ arm bushing install.......in pics
By sjsingle1 in forum Suspension and HandlingReplies: 6Last Post: 12-31-2012, 11:40 AM -
Help: Horrible Steering after bushing install
By kool-aide in forum Suspension and HandlingReplies: 2Last Post: 09-04-2008, 01:46 PM -
Question: Front A-Arm Bushing install
By kool-aide in forum Suspension and HandlingReplies: 10Last Post: 06-12-2008, 02:19 PM -
Front Sway Bar Bushing Install
By surfinjoe in forum GTOReplies: 4Last Post: 04-07-2008, 05:19 AM -
Energy Suspension Front LCA Bushing install
By lghtmup98 in forum Suspension and HandlingReplies: 0Last Post: 04-26-2006, 05:46 PM
