12-31-2012, 11:24 AM #1Senior Member
- Jan 2010
- texas
silver- 2000 formula
Poly TQ arm bushing install.......in pics
I have said it before and I will say it again......after 12 yrs......rubber in our cars turns to mush......no different for all the rubber in the suspension
the last piece in my suspension that is rubber was the TQ arm bushing.......not only old age but constant exposure to oil grease and other elements did it in
Energy suspension has 2 different P/Ns for their TQ arm bushing........1 for TQ arm lips that face towards the driveshaft......1 for the other way......mine faced away
Their bushing is a 1 size fits all 3rd-4th gen TQ arms....the difference is not the TQ arm........ but the bushing mount.........apparently the mount changed somewhere since 82 but the ES bushing has not......dont worry......just a little trimming is all it needs to work
it was about 13$ from summit
follow along
- - - Updated - - -
12-31-2012, 11:32 AM #2Senior Member
- Jan 2010
- texas
this is for auto tranny guys........dont have a clue about you manual guys
remove TQ arm......the bolts and nuts are 21mm.........remove driveshaft......4 bolts are 7/16.......remove crossmember..........4 ...15mm bolts.......remove tranny tailhousing......6....15mm bolts.......you may be able to do it without removal but its alot easier with it removed.....good time to inspect your tranny mount......it its the old stock rubber..........you will find it split and nasty.......the tranny tailhousing does have a gasket......i ordered one from the dealer but it still has not come in......so be forewarned about it
the TQ arm mount is held in with 3......15mm bolts nuts
you could be really anal and put in a new rear bushing and rear seal as well as the new front gasket....but did not have time for it this go round
- - - Updated - - -
- - - Updated - - -
12-31-2012, 11:33 AM #3Senior Member
- Jan 2010
- texas
- - - Updated - - -
the stock mount is 2 a piece shell......held in with rivets.....grind out rivets and remove from mount
12-31-2012, 11:35 AM #4Senior Member
- Jan 2010
- texas
test fit......mount all cleaned up......
- - - Updated - - -
you can see poly shavings from where i trimmed.........dremel tool comes in real handy for trimmingLast edited by sjsingle1; 12-31-2012 at 11:44 AM.
12-31-2012, 11:37 AM #5Senior Member
- Jan 2010
- texas
- - - Updated - - -
- - - Updated - - -
installed on tailmount
12-31-2012, 11:38 AM #6Senior Member
- Jan 2010
- texas
- - - Updated - - -
12-31-2012, 11:40 AM #7Senior Member
- Jan 2010
- texas
all in........now reverse install and get everything back on
- - - Updated - - -
- - - Updated - - -
and yes....i have a poly tranny mount
Poly torque arm bushing and clank noise
By JayTA98 in forum General HelpReplies: 0Last Post: 06-11-2010, 05:07 AM -
Question: gto poly bushing brand decision.
By red hot in forum GTOReplies: 9Last Post: 11-12-2009, 02:13 AM -
Question: Poly bushing set, yes or no???
By Musclecargt71 in forum Suspension and HandlingReplies: 9Last Post: 08-16-2009, 07:04 PM -
Question: Front A-Arm Bushing install
By kool-aide in forum Suspension and HandlingReplies: 10Last Post: 06-12-2008, 02:19 PM -
HP III/Spec Stage II/Poly Torque Arm Bushing
By 30birdy in forum Parts For Sale / TradeReplies: 7Last Post: 08-17-2006, 08:29 PM
