    Next... MrKid's Avatar
    Sep 2009
    Milford, CT
    '68 Camaro RS, '11 Camaro
    Heater Vacuum Control
    When I pulled my engine for rebuild, I removed all of the EGR and AIR plumbing. When I reinstalled the engine, I realized the heater won't switch from the floor to the dash vents. I didn't know this vac controlled. I found the line that runs through the fire wall, I'm just trying find where it goes to the motor. Can I just run it straight to the back of the intake, or do I need a check valve?
    old timer blue02Z's Avatar
    2002 Z28
    As far as i know you need a check valve. They commonly fail and that could be why it wont change. Does it stay on defrost all the time?
    Sep 2009
    Milford, CT
    No, it failed because I unhooked it by accident...lol.
    I have the check valve still, I just wasn't sure if i needed it or where texactly the line runs to on the manifold.
    Senior Member bills98ta's Avatar
    Feb 2007
    St Thomas, PA
    Back center of the intake, beside where the brake hose goes.
    Sep 2009
    Milford, CT
    Thanks. That's what I thought, but didn't want to just go for it. Should be fun getting my hand in there. Looks like I'll be deputizing the wife...
    Feb 2007
    St Thomas, PA
    Hang her by her ankles, then lower her down to the motor...
    Sep 2009
    Milford, CT
    Haha...I assume there will be requests for pics...
  1. Help: Trans Am engine Vacuum line for Vacuum/Boost Gauge
    By 1batt4u in forum General Help
    Last Post: 11-13-2014, 05:42 PM
  2. dont want a heater, heater hoses
    By tomcamaro97 in forum External Engine
    Last Post: 05-22-2014, 06:17 PM
  3. cruise control with traction control
    By basballny2 in forum General Help
    Last Post: 06-16-2010, 11:57 PM
  4. Control Arm Bushing Swap - Get In Control
    Last Post: 07-10-2009, 10:10 AM
  5. heater duct control
    By 1st TA in forum LT1
    Last Post: 08-24-2006, 04:33 PM
