Thread: heater duct control
08-10-2006, 01:48 PM #1
heater duct control
My boy has a 94 Z. When he is on the gas a little heavier the air coming out of the ducts will change outlets. Then when he backs out of it it changes back to where it was. What should I be looking for?
08-24-2006, 03:39 AM #26SpeedZ
- Virginia
Medium Patriot Red- 1993 Camaro
A new car?
08-24-2006, 04:25 AM #3Junior Member
- Jul 2006
- NC
the a/c vent controls are vaccum operated. I believe there is a check valve inline to keep the changing manifold pressure from affecting the vents until you actually change the switch. Also check your vaccum lines and make sure you don't have cracked a line or tore a boot
08-24-2006, 04:33 PM #4
If I start the car to get the vac. going then unplug the hose to the check valve should the check maintane the vac. if its good?
dont want a heater, heater hoses
By tomcamaro97 in forum External EngineReplies: 2Last Post: 05-22-2014, 06:17 PM -
Duct Soup - How A NACA Duct Works
By Ed Blown Vert in forum General HelpReplies: 0Last Post: 10-09-2013, 08:30 PM -
Question: Heater Vacuum Control
By MrKid in forum General HelpReplies: 6Last Post: 07-31-2010, 06:15 AM -
Cooling Mod Air Duct
By Shudson105 in forum External EngineReplies: 5Last Post: 06-27-2010, 12:28 AM -
Heater core plastic duct cover 1994 Z28
By Jason Polzer in forum Parts Wanted / TradeReplies: 4Last Post: 01-31-2008, 03:31 PM
