Thread: Drain a converter
07-28-2010, 08:43 AM #1LUCOMAN
- Jun 2008
- Guatemala City
Yellow- Z28 1998
Drain a converter
anyone know if it is possible to drain a vigilante converter, I HAVE A 4L60E AND THE 3TH AND 4TH FAIL, I WANT TO USE MY CONVERTER BUT I DON`T KNOW I THIS POSIBLE??
07-28-2010, 09:05 AM #2Junior Member
- Jul 2010
- Houston Tx
- 78 el camino
It real hard to do this,Is it a lockup? If it is you will unbalance it if you drill it on the side.if you drill it from the back it will be useless.It will mess up the lock up plate. if there's not any medal just stand it on the side and let it drain,lay it down for 30 min. then stand on side,repeat and that the best you can do unless you send it off to open it up.there's some mods you can do to help 3-4 clutches.Let me know if i can help.i have a trans shop and can give you info to help.Later!
send me a private message.
Steven
07-28-2010, 09:15 AM #3LUCOMAN
- Jun 2008
- Guatemala City
Yellow- Z28 1998
07-28-2010, 06:52 PM #4Senior Member
- Apr 2008
- Madison, WI
You'll never get it all out unless you cut it open.
07-28-2010, 09:37 PM #5
have you emailed precision industries and asked them about it? They may be willing to work with you on it and cut you a break.
07-29-2010, 07:15 PM #6LUCOMAN
- Jun 2008
- Guatemala City
Yellow- Z28 1998
07-29-2010, 10:13 PM #7Member
- Jul 2006
- Glen Carbon, IL
Silver- 2000 Camaro SS
Last time I checked with PI it's still $225 for a cut clean and restall. Fwiw, it was back in Feb that I checked. I ended up just buying a new converter and selling the old one.
07-31-2010, 08:19 AM #8
I lost the 3/4 pack 2 times(no metal in fluid)I drain conv each time and reinstall with no problem
just my .02
JohnnyY2K SS (SLP #239)
Completly STOCK heads/bore/stroke/weight
& NOTHING else ---is stock
"NAW-NAW- just a Sunday goto meeting car, my best time is not in the 12's------- any more "
ps: I am not soliticing work as I am retired
>>>info on alignments
http://www.jgruggles.com
oil drain plug size
By JoeRiceKillr in forum General HelpReplies: 5Last Post: 05-07-2018, 02:33 PM -
A/C drain line
By Young11b in forum External EngineReplies: 3Last Post: 08-04-2010, 04:35 PM -
Question: drain plug
By 2000dreambird in forum Manual TransmissionReplies: 6Last Post: 04-15-2010, 11:59 AM -
batt drain
By capemaydiamond in forum General HelpReplies: 14Last Post: 03-01-2010, 08:05 PM -
Question: Oil Drain Plug location?
By iceman504 in forum General HelpReplies: 12Last Post: 03-21-2008, 04:23 PM
