07-22-2010, 07:16 AM #1
Headlight issue @#$@#$% Any advice
I'm posting a video on what my headlights started doing last night. http://qik.com/video/9530188
Just started last night, I thought it was only on one side however one of my second opinion guys says it sounds like both.
07-22-2010, 07:21 AM #2
- Jan 2006
- Shepherd, Michigan
not a big deal..your gears are stripped. the gears only use 180 degrees ..so flip the gear and you will be all set.
07-22-2010, 07:28 AM #3
Really? Well damn! Thank you, I just need to do some research or better yet find a vid on how to take it apart.
Much appreciated
07-22-2010, 08:11 PM #4
I say buy the brass gears. Think about it...you gotta go into the motor and rotate the gear anyway, so why not just change the gear entirely? Rotating is a quick, but temp fix.
It's better to do it right the first time. I learned that after my first spat with the lamps.
07-23-2010, 04:50 AM #5
- Jan 2006
brass gears are incredibly hard on the motor..that motor is designed for light plastic gear ..you throw a heavy brass gear in there and watch your motor life go down the drain.
i've had my car for 3 years and i have yet to have a problem with the gears or the motor..the key is to only turn the light on or off..when you are at a complete stop.
07-23-2010, 05:40 AM #6
- Nov 2009
- Michigan
Black- 1998 Trans am WS6
Search "4th Gen Firebird Trans Am Headlight Fix" on youtube. The video explains how to rotate the gear. I found it helpful when I had to rotate the gear in my headlight.
07-23-2010, 03:13 PM #7
- Feb 2008
- Russellville, MO
07-24-2010, 01:41 PM #8
- Jul 2010
- Charleston, SC
Any pics of the brass gears? Could they be lightened by drilling holes in them before installation?
Headlight issue
By FutureWS6 in forum Firebird / WS6Replies: 17Last Post: 01-20-2011, 02:18 PM -
Yet another headlight issue
By JC70SS in forum Firebird / WS6Replies: 7Last Post: 06-19-2009, 12:16 PM -
Help: headlight issue!
By racingrev in forum Camaro / SSReplies: 4Last Post: 10-09-2008, 07:13 AM -
Headlight Issue
By Ws6 Love in forum Firebird / WS6Replies: 9Last Post: 07-31-2007, 08:40 PM -
Headlight Issue
By shlby123 in forum General HelpReplies: 1Last Post: 10-14-2006, 09:05 AM
