Thread: stupid question
07-21-2010, 03:44 PM #1Junior Member
- Apr 2010
- Orlando
Black- 2002 Camaro SS
stupid question
Okay,
I have a 2002 camaro and now it seems that I am getting a ton of water on my passenger side floor board. It has not rained and now I have standing water there. Any ideas? I am sure it has to do with the AC but I do not know where the drain would be to see if it was clogged. Any help would be appreciated.
07-21-2010, 04:36 PM #2
The only stupid question is the one that someone doesnt ask.
Check your Evap Drain tube on the passenger side firewall, you can use a metal coat hanger or screwdriver to ensure its not clogged.
07-22-2010, 05:45 AM #3LSwut
- Jun 2009
- Saint Louis, MO
Arctic White & Black- '98 WS6 M6 - SWAPTIME!
^^ agreed.
i had the same issue. except mine was kinked downwards. you should be fine once you unclog the tube.
07-22-2010, 06:20 AM #4
Worst case sinario, heater core. Does it have or smell like it has anti-freeze in it?
07-22-2010, 09:16 AM #5Junior Member
- Nov 2009
- GA
BLACK- 1999 camaro ss
yep what these dudes said. happened to me and it was a water bug stuck in there
07-22-2010, 09:34 AM #6
had this happen to me and went half the summer without running my ac. my drain hole was plugged, took me all of 30 seconds to fix. just use a long screw driver to clear the drain hole. located underneath the car, passenger side, by the header.
AC drain hole:
http://www.shbox.com/1/a_c_drain.jpg
07-22-2010, 09:39 AM #7Junior Member
- Apr 2010
- Orlando
Thanks Guys No it does not smell so I am guessing that is all it is. I will be crawling under it today to get it fixed.
07-22-2010, 04:51 PM #8Junior Member
- Apr 2010
- Orlando
Got it done... Wow there was a lot of water built up in there
07-22-2010, 07:32 PM #9Exalted Cyclops
- Feb 2007
- San Diego, CA
Fact: There are no stupid questions, only stupid answers...
That being said I tend to give answers that inject levity if not fact to the question asked...67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
Carbon footprint? CLOWN SHOE!
stupid question
By Lunatikgixxer in forum Firebird / WS6Replies: 18Last Post: 07-17-2010, 07:33 PM -
Stupid Question
By bsteff in forum Stereo and ElectronicsReplies: 15Last Post: 07-12-2010, 06:33 PM -
Question: stupid light stupid question
By TAallday in forum LT1Replies: 3Last Post: 08-26-2009, 10:58 PM -
stupid question
By FSANE in forum Political / Debate ForumReplies: 30Last Post: 10-25-2008, 06:12 PM -
stupid question
By chrombs13 in forum External EngineReplies: 2Last Post: 10-14-2006, 08:56 AM
