Results 1 to 16 of 16
Thread: Stupid Question
07-08-2010, 07:09 PM #1
Stupid Question
So I'm replacing my speakers and adding amps.....everything is hooked up, power to the amps....just won't turn on. Now, when you put a test light on the remote turn on wire it should light up right?????
07-08-2010, 07:14 PM #2
You should be getting power to the wire remote lead going back to the amp. Maybe a fuse? The amp power light is on?
07-08-2010, 07:14 PM #3
Could also be a bad ground
07-09-2010, 08:45 AM #4
07-09-2010, 08:52 AM #5its short but its skinny.
- Oct 2009
- The Woodlands/spring/houston
pewter- 99 trans am
what exactly wont turn on? the amps? the radiio? speakers? ...the remote wire merely sends a faint signal to the amp telling it to turn on..im not sure if there is enough juice there to power the test light.....best way to test that i have found is run a jumper from the hot wire on the amp to the remote terminal and see if you get power then...and what did you do with the factory amp (if equipped)? did you totally take it out of the equasion? ..using factory hu? more info please?
07-09-2010, 05:08 PM #6
07-09-2010, 05:10 PM #7
The light doesnt even come on from the hu though. Is it possible that part of the hu is bad?
07-09-2010, 05:12 PM #8its short but its skinny.
- Oct 2009
pewter- 99 trans am
Ok...this may sound dumb but it has happened....I once forgot to put the fuse in the main power block at the battery...also if the fuse holder is used, check to make sure it's got a tight grip on the fuse....and I would still try the jumper from the hot terminal to the remote terminal.
07-09-2010, 05:15 PM #9its short but its skinny.
- Oct 2009
pewter- 99 trans am
Also, some hu's come with 2 remote leads which both are blue....one for amp, other for power antenna....make sure you are correct there a well. What's the model #'s on the hu and amps?
07-09-2010, 05:17 PM #10
I need to go try the jumper.
07-09-2010, 05:18 PM #11
07-09-2010, 05:34 PM #12
So the jumper trick worked....i guess i need a new hu......
07-09-2010, 05:38 PM #13
07-12-2010, 03:24 PM #14
07-12-2010, 03:56 PM #15
07-12-2010, 06:33 PM #16Electrical Engineer
- Jul 2009
- North of the Motorcity
I agree here.
It typically takes 3 wires to fire up a HU. Sometimes the HU's actually label the wires, if not you can look up the model number or contact the manufacturer for which ones are which.
Usually go as follows;
Red = Switched Power (so it isn't running the whole time, killing your battery while not in use)
Black = Ground (common connection to complete circuit)
Yellow = Constant power (memory purposes, may not be needed) This can be wired with the positive terminal of the battery with the switched power, but make sure it's the correct one.
These wires are much thicker (smaller guage #) than the rest, the switched one might be smaller than ground/constant. Sometimes red and yellow are swapped, meaning red is constant power and yellow is switched.
Let us know.Last edited by KMdef9; 07-12-2010 at 06:39 PM.
stupid question
By cags07 in forum Camaro / SSReplies: 8Last Post: 07-22-2010, 07:32 PM -
stupid question
By Lunatikgixxer in forum Firebird / WS6Replies: 18Last Post: 07-17-2010, 07:33 PM -
Question: stupid light stupid question
By TAallday in forum LT1Replies: 3Last Post: 08-26-2009, 10:58 PM -
stupid question
By FSANE in forum Political / Debate ForumReplies: 30Last Post: 10-25-2008, 06:12 PM -
stupid question
By chrombs13 in forum External EngineReplies: 2Last Post: 10-14-2006, 08:56 AM
