Results 1 to 1 of 1
07-19-2010, 03:50 PM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
August 2010 Ford, Chevy & Dodge New Products - Tes
August 2010 Ford, Chevy & Dodge New Products - Test And Tune
Aeromotive's new fuel pressure regulators (PN 13217) for carbureted applications are stackable, allowing control over multiple pressure points with a single fuel pump. They're ideal for multistage nitrous systems, are completely serviceable in the field without removing them from the car, and are compatible with the Aeromotive A2000, A1000, Eliminator, and Pro-Series pumps.Stackable Fuel Pressure Regulators
Aeromotive
913/647-7300
AeromotiveInc.com
Aeromotive's new fuel pressure regulators (PN 13217) for carbureted applications are stackable, allowing control over multiple pressure points with a single fuel pump. They're ideal for multistage nitrous systems, are completely serviceable in the field without removing them from the car, and are compatible with the Aeromotive A2000, A1000, Eliminator, and Pro-Series pumps. Racers can simply bolt together as many of these regulators as needed using the provided capscrews, and they seal together with O-rings. They're made of billet aluminum, are adjustable from 5-12 psi, and have a -10 flow-through port and two -6 outlet ports.
Price: $163.50 each
August 2010 Ford, Chevy & Dodge New Products - Test And Tune | Digg It | Add to del.icio.us
More...
December 2010 Ford, Chevy & Dodge New Products - Test And Tu
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 11-16-2010, 05:20 PM -
September 2010 Ford, Chevy & Dodge New Products
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 08-05-2010, 02:10 PM -
July 2010 Ford, Chevy & Dodge New Products - Test
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 06-23-2010, 02:20 PM -
June 2010 Hot Rod Ford, Chevy & Dodge Performance
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 05-19-2010, 05:00 PM -
Chevy, Dodge, or Ford??
By Hotrod in forum GM TrucksReplies: 49Last Post: 08-04-2006, 05:10 PM
