Results 1 to 1 of 1
06-23-2010, 02:20 PM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
July 2010 Ford, Chevy & Dodge New Products - Test
July 2010 Ford, Chevy & Dodge New Products - Test And Tune
Mechanical fuel-injection stacks are just plain cool. Converted to electronic fuel injection, they're actually usable on the street. Inglése's new Eight Stack Induction System is a mechanical-looking fuelie setup with cast-aluminum, 50mm, IDA-style throttle bodies controlled by FAST's EZ-EFI fuel injection for the best of both worlds.Eight Stack EFI
Inglése
866/450-8089
inglese.com
Mechanical fuel-injection stacks are just plain cool. Converted to electronic fuel injection, they're actually usable on the street. Inglése's new Eight Stack Induction System is a mechanical-looking fuelie setup with cast-aluminum, 50mm, IDA-style throttle bodies controlled by FAST's EZ-EFI fuel injection for the best of both worlds. A handheld EZ-EFI tuner means you don't need a laptop. Simply answer a few easy questions on the controller and it will use that information to establish the baseline tuning file and then learn as you drive, while homing in on the optimum tune. The custom-engineered, low-profile fuel rails sit below the stacks and between the throttle bodies for a clean look. Aircraft-quality aluminum linkages are employed to provide smooth actuation, and systems are available for a wide variety of popular V-8s. Many custom options are available, including the two stack heights seen above.
Price: $2,995.00 and up
More...
December 2010 Ford, Chevy & Dodge New Products - Test And Tu
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 11-16-2010, 05:20 PM -
September 2010 Ford, Chevy & Dodge New Products
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 08-05-2010, 02:10 PM -
August 2010 Ford, Chevy & Dodge New Products - Tes
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 07-19-2010, 03:50 PM -
June 2010 Hot Rod Ford, Chevy & Dodge Performance
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 05-19-2010, 05:00 PM -
Chevy, Dodge, or Ford??
By Hotrod in forum GM TrucksReplies: 49Last Post: 08-04-2006, 05:10 PM
