    Feb 2006
    GARDEN GROVE, CA
    BLACK
    2002, CAMARO Z28
    shifting sloopy at times and notchy
    For instance I will drive to work it the shifter might shift smooth and light action and then on the way back from work it will shift notchy and sloppy and I will hear a slight clunk going into gear. What's going on?
    Member lrader99's Avatar
    NW Georgia
    flat black
    is it in every gear?
    Feb 2006
    GARDEN GROVE, CA
    BLACK
    2002, CAMARO Z28
    Yes all gears. Today it's shifting smooth most of the time.
    2002 Camaro z28, m6, direct flow lid, maft, powerstick muffler with stainless z28 tips, lakewood lca, predator, vacuum gauge inside car, ngk tr55, msd wires
    stock dyno 310 rwhp, 329 trq
    SoCal
    Mag Red
    '98 C5
    Sounds like a problem with either your master or slave not allowing your clutch to disengage fully
    Junior Member stevo5662's Avatar
    Feb 2006
    california
    1998 Z28 6-speed
    i just had the ls7 clutch put in mine and im having the same issue. its inconsistent on when i have the problem and the pedal never feels different. the pedal also feels great btw. but when i shift it feels like the gears are catching a little bit. also getting into reverse is a B!TCH
    Junior Member swimster144's Avatar
    Feb 2006
    Colorado
    Pewter Metallic
    1999 Camaro Z28 M6
    I dunno you guys, but this kind of thing is pretty normal for Camaro's and TA's...
    Member tici's Avatar
    Zurich - Switzerland
    1998 M6 vert TA
    Mine also acts every day a little different, depending on the mood
    It shift better when:
    - the tranny is warmed up
    - I shift at high rpm (the higher the better)
    I have a 97 Borg Warner with mineral ATF. I also tried the super expensive GM synchromesh: it shifts smoother but it's still not perfect. It also shifts harder in winter so I went back to ATF.
  1. Notchy 1-2 shift
    By redbird555 in forum Manual Transmission
    Last Post: 09-18-2012, 06:27 AM
  2. why is the t56 notchy?
    By 1999slpss in forum Manual Transmission
    Last Post: 01-15-2012, 08:55 AM
  3. shifting rpm
    By mxlplx71 in forum Drag Racing
    Last Post: 06-01-2010, 05:24 PM
  4. Notchy shifts in my T56
    By Cutlass in forum Manual Transmission
    Last Post: 05-05-2008, 09:34 PM
  5. A4 not shifting
    By mysticZ in forum Automatic Transmission
    Last Post: 08-31-2006, 05:20 PM
