Results 1 to 13 of 13
Thread: A4 not shifting
08-21-2006, 05:22 PM #1Member
- Aug 2006
- NC
mystic- 95 LS, yes it says LS
A4 not shifting
Trans wont shift. 4L60E Every gear is drive (not revese) Fluid is good. ANY HELP IS NEEDED.
08-21-2006, 05:33 PM #2
need more info.. does the car drive just fine and won't go into park, neutral, reverse, ect?? maybe something as simple as a broken shift cable..
Alright... I'm starting it now. Try not to piss yourself.
08-21-2006, 05:56 PM #3Member
- Aug 2006
- NC
Every letter and number on the shift pattern you put the shifterin is like D1.
08-23-2006, 08:50 PM #4
man, still need some more info. I have a next to nothing clue of what your talking about.
08-24-2006, 04:55 AM #5
Im assuming what you actually mean is the all the forward positions are 3rd gear , starts in third ends in third and that park, reverse.neutral are normal ,
This would be and electronics failure ,It could be anything from a failed solinod to the harness being disconected from transmission ,
First I would check just that the harness make sure its plugged into trans , next check fuse box for blown fuses , It you find both are ok have car scanned at a transmisions hop or I beleave auto zone does this also , Be sure and have them give you the code numbers not just tell you what they mean ,
If available at a local transmission shop ask them if they have a shafer shifter , they will know what it is , Have them hook it up and withn this tool they can eliminate transmisions electronics and you will know its a vehical elctronics issue .
If you get those codes send them to us and we will try and help you out .
thanksLast edited by mrr23; 11-26-2006 at 05:11 PM. Reason: removed link to website. contact ed blown vert for sponsor information.
08-27-2006, 01:05 PM #6Member
- Aug 2006
- NC
Thanks for the help!!!! It ended up being the cable.
08-27-2006, 02:08 PM #7
hell yeah!! everyone give juiced some props! lol
08-27-2006, 02:10 PM #8
now vote to make me a mod lol
08-27-2006, 02:17 PM #9
Some times we all assume , the worst , but then I did say provided park reverse and neutral are working ok and I would say they were not lol , anyway glad it was something simple ,
Last edited by mrr23; 11-26-2006 at 05:10 PM. Reason: removed link to website. contact ed blown vert for sponsor information.
08-28-2006, 01:04 PM #10Member
- Aug 2006
- NC
08-28-2006, 03:02 PM #11Member
- Aug 2006
- NC
Need to know if the cable is adjustable, if so, where.
08-31-2006, 05:17 PM #12
mine did the same thing your describing now and did get adjusted.. let us know what fixes it
08-31-2006, 05:20 PM #13Member
- Aug 2006
- NC
PAIN IN MY ACE. Got the cable adjusted. Only took tree days to find the adjustment on it. I get my car back friday. It will be the first time in two years that I get to drive it. Thanks for all the info!
not shifting
By 346ci in forum Automatic TransmissionReplies: 16Last Post: 05-29-2014, 02:17 PM -
05 and 06 shifting
By 06goat60 in forum GTOReplies: 7Last Post: 09-07-2008, 04:01 PM -
Shifting
By 01ws6er in forum Drag RacingReplies: 21Last Post: 03-19-2008, 06:31 AM -
Shifting
By TopForm11 in forum Automatic TransmissionReplies: 1Last Post: 03-14-2008, 01:51 PM -
Shifting help!!!!
By clg82 in forum Automatic TransmissionReplies: 2Last Post: 12-28-2007, 01:07 AM
