Results 1 to 20 of 32
Thread: shifting rpm
05-26-2010, 05:37 PM #1
shifting rpm
when racing what rpm do you shift your m6? my car is stock.
05-26-2010, 08:14 PM #2
I shift at about 6100 RPM. If I remember right, your peak power is at about 5,500 RPM. So Ideally, after you shift you want to be in the highest part of your powerband to maximize your car's potential.
05-28-2010, 11:26 AM #3
- Nov 1999
- over here...
i shift at 6200 - 6500... but i have an ls6 that i dropped in...
05-28-2010, 11:35 AM #4
I think redline on the LS1 is 6300 if I remember right. So after shifting at 6100 (when I start to shift) it probably is at about 6200-6250...hard to tell really without a digital read out or data logger.
05-28-2010, 11:42 AM #5
05-28-2010, 11:44 AM #6
05-28-2010, 11:44 AM #7
My DYNO graph of my car had results up to 6260 RPM.
05-28-2010, 11:49 AM #8
05-28-2010, 11:57 AM #9
I don't think any shop would raise your rev limiter without telling you
05-28-2010, 12:55 PM #10
- Nov 2006
- Indianapolis
And you don't want to rev it past 6200 with the stock pushrods, they can't take it. I shift near 6150, sometimes I bump the rev limiter just before I shift. I've found this gets the extra couple tenths at the drag strip, instead of shifting at any lower RPM.
05-28-2010, 01:06 PM #11
6,500 rpms but mods in sig
┌∩┐(◕_◕)┌∩┐
wouldn't want to fight them!
05-28-2010, 01:57 PM #12
- Mar 2009
- Milwaukee
Arctic White, red/gray- 1997 Corvette, 92 Typhoon
05-28-2010, 08:24 PM #13
the lifters rattle around 6grand
05-28-2010, 08:52 PM #14
- Nov 2009
- Jacksonville FL
TRIPLE BLACK- 2000 CAMARO SS M6 #2100
Man, I guess I shift a lil low... I try not to ever let it go too far past 6k at all. Then again I have the stock pushrods in until I get off my lazy ass and put in the comp cams chromoly ones I’ve got collecting dust in the garage.
05-28-2010, 09:02 PM #15
i try to shift before 6 but they still rattle alittle, im using mobil 1 5w30 syn
should i switch oil to 10w30? i used to use 15-50 in my turbo cars.
05-29-2010, 03:54 AM #16
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
I'm right around the same of 6150-6200 or so. Every car is going to be a little different, so I'd say just practice with shifting at different rpms to see what gives you the better times. And because your stock I wouldn't go above 6000 rpm just to be safe.
05-29-2010, 06:19 AM #17
- Jul 2006
- Glen Carbon, IL
Silver- 2000 Camaro SS
Stop posting false information.
My car for example is a stalled A4 with a cam and nitrous (hardened pushrods of course). My rev limiter is set at 6800. It puts out it's best track times by shifting at 6500. I've bounced the rev limiter on the bottle at the track by forgetting to take it out of 2nd gear after my burnout. I not only did I launch in 2nd gear on a 200 shot, but I hit the rev limiter too. I reviewed the log and was amazed to see 7950 since it revved so fast on the bottle. I was lucky that the stock bottom end didn't let go.
05-29-2010, 08:50 AM #18
05-29-2010, 10:11 AM #19
Lifters shouldn't rattle around. I find that impossible to happen unless there is slack in the valvetrain. Now, a lifter may be on its way out and ticking
05-29-2010, 10:27 AM #20
it makes a rattleing sound every once in a while on a hard run, mybe the oil is too hot or too thin its new mobil 1 , i may take a qt or 2 out and put in alittle 15-50
not shifting
By 346ci in forum Automatic TransmissionReplies: 16Last Post: 05-29-2014, 02:17 PM -
05 and 06 shifting
By 06goat60 in forum GTOReplies: 7Last Post: 09-07-2008, 04:01 PM -
Shifting
By 01ws6er in forum Drag RacingReplies: 21Last Post: 03-19-2008, 06:31 AM -
Shifting help!!!!
By clg82 in forum Automatic TransmissionReplies: 2Last Post: 12-28-2007, 01:07 AM -
A4 not shifting
By mysticZ in forum Automatic TransmissionReplies: 12Last Post: 08-31-2006, 05:20 PM
