Results 1 to 10 of 10
Thread: knock sensor
06-29-2010, 03:58 PM #1
knock sensor
So I got my car scanned today and it came up with a knock sensor code... I know this sounds like a I big newbie question but what am I looking for in figuring out if its a knock or if the sensor is just bad? Also where r the knock sensors located on a 98 ls1?... I'm terrible with diagnostics so please go easy on me ha
06-29-2010, 06:36 PM #2
- Apr 2008
- Madison, WI
the knock sensors are under the intake manifold and most likely its a bad sensor
06-29-2010, 06:49 PM #3
Agreed. Water getting under the intake and deteriorating the sensors is common. You'll want to replace both.
06-29-2010, 06:53 PM #4
do you or have you washed the engine down with a garden hose?
06-30-2010, 08:38 AM #5
I do wash my engine bay about once a month but im very careful on how much water i use. I hopeI wont get issues from water. thats why i also didnt remove the foam strip when i swap my LS6 intake
06-30-2010, 10:34 AM #6
Haha no I'm scared to get all those electronics wet on top of the engine let alone the ones that are apparently hiding under the intake now that's not to say that the old owner didn't
now should I be concerned about iy being an actual knock or is it most likely the sensor?... the motor is pretty much well untouched from factory and it has 170k on the clock
06-30-2010, 11:44 AM #7
There is a gm bulletin that says when you replace your sensors you should make a dam of rtv around the holes to keep water out. Your harness is probably all corroded too. You should replace both sensors, the harness, and make dams around them to keep water out
06-30-2010, 12:31 PM #8
06-30-2010, 06:42 PM #9
what was the actual code? Most likely it's a bad sensor.
07-01-2010, 06:11 AM #10
knock sensor code with new knock sensors?
By zaaronz in forum General HelpReplies: 13Last Post: 02-27-2011, 06:26 AM -
Knock Sensor ?
By Jheath5193 in forum General HelpReplies: 1Last Post: 01-20-2011, 02:31 PM -
Which knock sensor do I need?
By SMWS6TA in forum General HelpReplies: 7Last Post: 12-27-2010, 10:09 PM -
will bad knock sensor knock down hp
By zaaronz in forum General HelpReplies: 11Last Post: 10-14-2010, 04:49 PM -
Knock Sensor/Oil Pressure Sensor Issue
By Slow '99 in forum External EngineReplies: 1Last Post: 04-04-2007, 08:28 AM
