Results 1 to 20 of 27
    Senior Member Sleeper101's Avatar
    Springcity
    Vette,240sx,ls1 camaro
    turbo 5.3 ls Blow threw carb setup 240sx
    Well i sold my turbo 6cyl out of my 240sx, So i figured I would up grade some cubic inches and see what happens under boost. Im going to start out around 15psi and see how the car responds. Should be a good combo when im done.
    Basic setup: Engine
    2000 5.3 (Stock internals)
    Stock coils
    Gto oilpan
    ls1 carb intake
    Quick fuel Blow threw carb
    MSD stand alone ignition
    tci flex plate (th400)
    Trans Dapt motor mounts
    60mm Precision turbo
    synapse wastegate
    hks bov
    Water intercooler with ice tank and pump
    Transmission:
    Turbo 400 with transbrake
    3500stall
    ratchet shifter
    Shaftmasters Custom driveshaft
    suspension:
    Brembo drill/slotted rotors
    ss brake lines
    Hurst line lock
    Rebuilt stock calipers
    New struts with Tein lowering springs (rear modified more)
    New axles (stock r200 welded rear end)
    Wicked racing adjustable control arms
    Weld Drag lites 15x4 Front 15x8 rear 5.5 backspacing
    Nexen front runners
    M/t 26x10.5 et streets rear
    I got the fire wall painted
    Had to move the radiator to clear the turbo. built a new support and made new headlight brackets and hood latch bracket.
    Had to notch the frame so the lower radiator hose will fit in the new location.
    Gto oil pan
    Performer carb intake
    specter carb hat
    new fuel pump
    new fpr
    Turbo and turbo manifold mounted.
    Motor mounts
    Fear The Reaper IceeWS6's Avatar
    Asheville, NC
    Pewter Metallic
    '02 WS6 M6 - The Reaper
    subscribed for results
    Springcity
    Well I would be a lot further along, but I been waiting on a transmission for a month. I'm getting my money back. I'm thinking about getting a power glide w trans brake now. I think it will fit my setup pretty well. Once I get a trans I can get the motor set in place and get all my little things done.
    Aug 2010
    tulsa
    2000 s10
    any updates on this build
    Senior Member 00z28bubba's Avatar
    las vegas, nv
    2000 Z28
    what made you decide to go carb with the turbo??? lack of tuner issue???
    Senior Member
    Mar 2009
    Milwaukee
    Arctic White, red/gray
    1997 Corvette, 92 Typhoon
    Quote Originally Posted by 00z28bubba View Post
    Cause blow through carbs with turbos rock. It doesnt limit the power if thats what your thinking
    las vegas, nv
    2000 Z28
    i know its a vague question but what is the advantages, if any, of a blow through over efi?
    Springcity
    and here is the most recent photo's got the intercooler piping welded up
    Pittsburgh
    2008 Hummer H3
    Ease of using just about any motor for a project car.
    You can make on the spot adjustments with not much need for a laptop or a professional tuner..
    No PCM persay= no SES lights for things that don't need to be on an engine to begin with..
    Partly the reason I went stand alone on the TT build..
    It does'nt need all the extra electronics to operate the engine..
    Then there's also the fact that with a carb the engine bay on a custom is usually much more neat.. No octopus of wire bundles running everywhere..
    Just engine.. As it should be..
    Import Ambassador nomolos1's Avatar
    Jul 2010
    Georgia
    black, black Twins
    93 Supra , 94 Supra Turbo
    Gonna need some clamps on all the couplers.
    Have you gave the car a name yet? I think Brutus would be a good one. I've seen these cars with LS1s in them. Very beastly. But with an LST....Well that should be a traction challenged queen.....lol These cars are so light weight as it is. I see a 13 second car with a 160 mph trap. You might be 3/4 down the track before it hooks...lol
    It looks great. Can't wait to hear its dyno results. I'm guessing 800s on a light tune.(pump gas)
    Springcity
    Sorry guys its been a min since I've been on here, been trying to finish this project. If all my fuel fittings come in this week I'm going to fire it up this weekend. As for the carb, no lack of tuner, I've always done all my own tuning on the laptop, I'm just tired of injection, wiring is a hassle and seems like there is ALWAYS a problem. + with a carb the engine bay is super clean. I have never ran a blow threw setup, this is my first so its a learning experience for me. As for hp, I won't put down 800 lol, its a BONE stock 5.3, all the way down to the stock rod bolts, I wanna see wat these motors will truly hold, I have heard a lot of stories, on a serious note I think the most I will make is 650 on pump gas. Traction will not be an issue either, I've got the suspension
    Setup pretty well, but will see wat the bumper looks like after a transbrake launch.
    Jul 2010
    Georgia
    black, black Twins
    650 is very respectable. Especailly with a light weight, like a 240. Spool time should be a low rpm too.
    The Supra spools around 2300 to 2600 rpm. An LS should be around 1800 or less. Did you lower your compression, or keep the stock size head gaskets?
    Springcity
    Its stock compression, stock head gaskets, I've not touched anything internally, I'm going to start out around 10psi and get a good tune on it, I'm going to keep it a little rich around 12.0-12.4, then ill gradually up the boost to somewere around 15-20psi.
    Jul 2010
    Georgia
    black, black Twins
    I would get a meth kit. You want to be very careful of detonation. That is mainly what it is there for. Most of us meth junkies just add more boost. It's about 500 or so for the kit. Plus about $30 to refill a 5 gal container. I used the windshield wash container, because it hold a gal, instead of the 1 pint container that comes with the kit. Depending of your driving habits, 1 gal can last you a week or a month. Since I used the ww reservoir, I have the low fluid light when it is low.
    Springcity
    I am running a water intercooler, so it will have ice in it when I'm at the track making hard passes, shouldn't. Have much issue's with detonation. But ur right it does kill the motors quick.
    Jul 2010
    Georgia
    black, black Twins
    Well if you are just running at the track, the IC would be the way to go. I thought you might be terrorizing C6 Z06s on the streets....lol
    Springcity
    I will only need half throttle for the street boys lol, I am going to drive it on the street, but I won't be making much of a show till I hit the track, but thanks for the alky advice, I may use it in the future, just not on my to do list yet.
    Springcity
    Well I finished my fuel tank friday, got my fuel sump built and fittings in, friday night I finished my fuel lines + filter, and some more wiring, and I fired it up for new yrs! Wahoo lol, it sounds great with an exception of 1 lifter still not building up. Looks like I'm gonna have to pull the valve cover n see wats up.
    Springcity
    Well after several months of battling motor issue's I'm finally making some progress again. Ended up with a 5.3 block punched to 5.7 scat h-beam rods, je forged pistons, arp everuthing, 614lift comp turbo cam etc. Here's the 1st start.
    http://m.youtube.com/watch?gl=CA&cli...&v=Ggt1x2Q2HGM
    Jul 2010
    Georgia
    black, black Twins
    link not working
  1. few track video's of my turbo lsx 240sx and kills
    By Sleeper101 in forum Kill Stories
    Last Post: 08-30-2011, 07:49 AM
  2. turbo ls 240sx vs turbo mustang + video
    Last Post: 07-26-2011, 09:44 AM
  3. My 5.3Ls blow threw Turbo 240sx build
    By Sleeper101 in forum Drag Racing
    Last Post: 12-15-2010, 10:03 AM
  4. 2 step setup with blow thru carb?
    By Sleeper101 in forum Forced Induction
    Last Post: 05-21-2010, 02:55 PM
  5. blow thru LS turbo
    By olds powered in forum Forced Induction
    Last Post: 04-19-2010, 09:40 PM
