Thread: blow thru LS turbo
04-16-2010, 06:11 PM #1
blow thru LS turbo
is anyone running a blow thru turbo setup? i have a 5.3, i am gonna slap a turbo on it but dont know if i should stick w/ EFI or carb. if anyone of is running a blow thru carb setup let me know hows it goin & how u like it.
thanx
04-18-2010, 07:42 PM #2Junior Member
- Nov 2008
- wyoming
silver- 2005 silverado
I would do a blow through carb for the easy and cheap street. I've seen people struggle and end up buying a motec or big stuff EFI system.
04-18-2010, 10:46 PM #3
i thought efi and boost were the only way to go since the t-types and grand nationals went efi in 84. prior to that they were still turbod 6 but with a carb that picked up like 20 hp over the stock 3.8. when they went efi it was a huge jump in power. pretty much a big enough jump after efi and intercooler that they beat out the similar year vettes in power and straight line performance in 86(i think) and 87(for sure). didnt know a lot of people built carbed turbo set ups.
04-19-2010, 09:40 PM #4Member
- Nov 2006
- Sunniest city on Earth
- 2011 Silverado CC 4x4 6.2
Most people build turbocharged engines with EFI for purposes of easy tunability. There is a lot going on with turbos and the EFI makes organizing everything ridiculously easier. There are a bunch of guys out there running turbochargers into blow-through carbs and making big power, so if you do your research you should be just fine. I honestly believe that you would be better off tracking down people who have these cars and picking their brains than asking on here, due to the EFI-oriented nature of the forced induction on this forum. Talk to some carb manufacturers and tuners and you should be fine.
turbo 5.3 ls Blow threw carb setup 240sx
By Sleeper101 in forum Domestics and ForeignsReplies: 26Last Post: 01-29-2012, 01:57 AM -
My 5.3Ls blow threw Turbo 240sx build
By Sleeper101 in forum Drag RacingReplies: 2Last Post: 12-15-2010, 10:03 AM -
Blow it up
By Trolleyman in forum Western MembersReplies: 4Last Post: 12-10-2007, 02:24 PM -
Blow-by, can PCV help?
By 99bluebird in forum Internal EngineReplies: 2Last Post: 09-10-2007, 09:53 PM -
can i get a blow?????????
By redz284u in forum General HelpReplies: 3Last Post: 10-19-2005, 11:24 AM
