Results 1 to 20 of 31
06-12-2011, 06:16 PM #1
turbo ls 240sx vs turbo mustang + video
Went to the track last night to run our local street class called true street. Basically its a run wat u brung hope u brought enough on drag radials and stock suspension. There full street cars not drag cars. My 240 went 7.23@99mph, I have a fuel issue and it kept nosing over 150ft before the finish line. The mustang went 7.92@94mph, he said his car was popping.
I had the 240 de-tuned, I have the wrong ign box so I cannot take timing out for boost yet. So this pass was on 3.5-4psi. We had some good races last night. Had a blast, next time I go I'm shooting for 6.00
[ame]http://www.youtube.com/watch?v=TNu-DErE6kc[/ame]
06-12-2011, 06:22 PM #2
Fast car, hard to describe it as a sleeper. What i could see of it anyway.
06-12-2011, 06:30 PM #3
Lol, thanks, its kinda transformed this past year. Hard to hide it all
, I can't wait to get it tuned on 18-19psi + some new drag radials and the transbrake launch. My et streets I ran last night are so wore out there down to the nylon now. It started spinning out of the hole a lot towards the end of the night.
06-13-2011, 09:35 AM #4Senior Member
- Mar 2009
- Milwaukee
Arctic White, red/gray- 1997 Corvette, 92 Typhoon
Glad to see its up and running and making passes. Very cool
06-13-2011, 11:44 AM #5
I think I figured out why it was laying over. My current setup I have a dual feed line on the carb fed from one -6 line off my regulator, my regulator has a place for 2 -6 feed lines. My problem is its trying to fill the front bowl as fast as the 2nd bowl and its running the 2nd bowl dry. I need to come out of my reg with 2-6 lines feeding each bowl separate. Guess this is how u learn ur mistakes lol.
06-13-2011, 12:26 PM #6O U 8 1 2
- Nov 1999
- over here...
nice!!!
06-13-2011, 12:29 PM #7
Sweet.
Pics of engine bay!
06-13-2011, 05:37 PM #8
06-13-2011, 05:42 PM #9
Holy shiny turbo piping, Batman! Looks like fun/trouble.
06-13-2011, 11:10 PM #10
06-14-2011, 12:38 PM #11
I went to the track thinking its going to be a hand full. But I was totally surprised, it went straight as an arrow. I've never drove one with as much power + light weight as it makes and it go as straight as it does. Let's just hope it stays this way when I add more boost
06-14-2011, 02:13 PM #12
What sort of differential you run in that? Stock or modified to a solid axle?
06-14-2011, 02:23 PM #13
Its stock independent suspension, rear end is welded with factory 4.08 gears. I have another differential I built with 3.56 gears if I need it.
06-14-2011, 02:44 PM #14
Cool beans. How much power do those things hold up to?
06-14-2011, 06:27 PM #15
The rear end itself is bullet proof, but the axles are the weak link. I've personally have broke a few sets myself. I've figured out over a few yrs the axle angles play a huge roll on what they will and will not hold. So far I have put down over 500 @ the tires and its held fine since I've made a few angle changes. I plan on putting 600-650 @ the tires with this setup.
06-15-2011, 07:15 AM #16Senior Member
- Mar 2009
- Milwaukee
06-15-2011, 07:35 AM #17
It is a small turbo its a 60mm, it makes more tq than anything which is what I need running 1/8th mile.
06-15-2011, 07:45 AM #18
The air was horrible that day, we was looking @ 4500 above sea, + I later found (next day) my brakes was dragging bad. I kinda noticed it but didn't have a chance to check it out. Found my nut back off my brake pedal and the rod was tight, I loosened it 1/2". The car rolls SO much better now. I bet the car picked up nearly .500 just due to brakes. I will get the bugs worked out. Its been a long project.
06-15-2011, 09:52 AM #19Senior Member
- Mar 2009
- Milwaukee
06-15-2011, 10:27 AM #20
Ya ur right it can be made up in the gearing. A buddy of mine has been Busting these guys ass that has 90-106mm turbo's with his small turbo like mine. He's gone before there's gets spooled up they trap A LOT more mph, but he has such a good 1st half track they cannot catch him. Its all about the combo, will see how far this setup goes, I may change turbo's later on. I've left plenty of room on everything to upgrade.
turbo 5.3 ls Blow threw carb setup 240sx
By Sleeper101 in forum Domestics and ForeignsReplies: 26Last Post: 01-29-2012, 02:57 AM -
few track video's of my turbo lsx 240sx and kills
By Sleeper101 in forum Kill StoriesReplies: 6Last Post: 08-30-2011, 08:49 AM -
My 5.3Ls blow threw Turbo 240sx build
By Sleeper101 in forum Drag RacingReplies: 2Last Post: 12-15-2010, 11:03 AM -
my ws6 vs turbo 07 mustang gt 3v
By jdcws6 in forum Kill StoriesReplies: 13Last Post: 07-30-2010, 12:51 PM -
turbo mustang
By c5z28 in forum Kill StoriesReplies: 5Last Post: 07-21-2009, 11:30 AM
