    Member 02fbody35th's Avatar
    Feb 2008
    scranton,pa
    2002 camaro 35th anv.
    power steering whine
    does anyone else have a problem with powersteering whine on their cars. i did the pump on my car and i returned it like three times because they all had a slight wine. not really at idle but higher rpms. the steering works great and the system was properly blead. i dont know i guess i just have to learn to live with it. what do you guys think?
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Does it do that when hitting the lock(turning the wheel all the way to right/left)?
    Member raysz28's Avatar
    Central Ohio
    Ticket Red
    M6 1998 Z-28
    Quote Originally Posted by 02fbody35th View Post
    So if i understand this correctly...you have had 3 new/reman pumps?
    Two things to try...
    first make sure that you have pushed the pulley ALL the way back on so that its not squeaking from the belt.
    Second...save yourself from future headaches and order a TurnOne PS pump. If you do any aggressive driving at all, its worth every penny!!
    http://www.turnone-steering.com/pumpdirectory.html
    98 Ticket Red Z28
    Mods:
    Front/rear sway bars, poly bushings all around, Bilstein Shocks, Centerforce Dual Friction Clutch, Pacesetter LT's, 2.5" Custom True Duals over the axle with Magnaflow mufflers, Shortened Pro 5.0 shifter, TurnOne PS pump.
    Member DaddySS's Avatar
    Bergen Co. NJ
    2000 Camaro SS Conv.
    What kind of fluid are you using? How long has the pump been in there and is it still whining now? Are you sure it's the pump whining?
    Feb 2008
    scranton,pa
    yes, i am possitve it is powersteering whine, deffinatly not a belt noise. it does it whenever the revs climb. the wheel doesnt even need to be turning. and i use valvoline powersteering fluid. turn one pumps sound great but i went with the reman because of price.. the whine isnt terriblly loud but it is their.
    are you sure you have enough fluid???
    new jersey
    navy blue metallic
    2000 trans am
    I just replaced my pump with one I had rebuilt from a company called PSC. They build steering stuff for rock crawlers. They modify it the same way Turn One does, but they only charge $100 for it plus shipping both ways. Since it's underdriven it's a little harder to turn when sitting completely still and you can feel a little rumble but it doesn't bother me. Makes me feel better knowing it'll never die during autox or anything.
    On a side note, I replaced my pump because I autox so I needed one anyway, and thought mine was whining. Turns out it's my waterpump (I believe) making all the noise now. It is a LOUD whine, I can hear it clearly over my LT/ORY/Magnaflow exhaust. People ask me if my car is supercharged. I never did anything about it because I thought it was just my ps pump for the last year. Just check to make sure it's not that before you buy anything. It's tough to hear exactly where it's coming from with so many moving parts.
    Pittsburgh
    2008 Hummer H3
    Imho it's the reman.. Always best to buy new imho.. @ least it seems that way anymore.
    Feb 2008
    scranton,pa
    yeah i think your right about the remans. it deffinatly has enough fluid and i know it is the pump nothing else. i checked it out im 100% positive.
  1. Power steering Whine
    By theorangeguy in forum General Help
    Last Post: 08-09-2015, 06:37 AM
  2. Help: Whine from Power Steering Pump?
    By BurgerB in forum General Help
    Last Post: 04-24-2013, 02:55 PM
  3. Power Steering Pump Whine
    By kenji226 in forum External Engine
    Last Post: 04-30-2012, 05:06 PM
  4. Question: Power Steering, Manual Rack, Power Steering Pumps-etc
    By TerribleTed in forum General Help
    Last Post: 11-18-2010, 04:37 PM
  5. Help: power steering whine
    By 02fbody35th in forum General Help
    Last Post: 04-06-2010, 04:43 PM
