Results 1 to 3 of 3
11-17-2010, 09:14 AM #1TerribleTed
- Jan 2010
- California-Sacramento-Roseville
Red- 2000 Chevy Camaro Z28
Power Steering, Manual Rack, Power Steering Pumps-etc
Howdy all,
so as we all know the power steering pumps in many stock camaros is a little weak.
I have replaced mine (with a kragen or autozone krapper) and the high pressure hose not buy a year ago and already the pump seems to over heat more than I like.
I have cleaned out the PS cooler device-it seems fine to begin with and now just think I need to upgrade the PS pump to perhaps a (year one) pump which I heard are built bad azz...but wonder a few things on this system.
1. Can I use my stock PS fluid lines for the (year one) pump and if not-how or what is needed to use the AN type fittings with the stock hoses? Do I need to have custom PS hoses made with correct AN ends?
I am not even sure if I got the AN correct,,,is it IAN or AN?
Also to those that changed there PS to a manual rack-how is the manual system for daily driving or is the manual pureply meant for drag only style,,,
11-17-2010, 07:12 PM #2
hmmmm... you can buy a universal trans cooler and route your own lines to the cooler because if you have a stock cooler like i do than it will only get as cool as your coolant which is ~195* or so. if you make your own cooler and put it up front it will cool more efficiently. i dont know squat about year one pumps but i can only assume you will pay your first born child for one. and as far as manual racks.... idk. 2 of my first gen camaros have manual rack and pinions and they are tough slow speed but great once your rolling, but they were designed for that
11-18-2010, 04:37 PM #311 years of bangin gears
- Jan 2009
- North Jersey
Maybe swap the power steering pulley to a smaller diameter pulley? IMO, if you're daily driving your car, I would advise against converting to manual steering.
power steering vs manual..
By Firebirdformula in forum Suspension and HandlingReplies: 18Last Post: 09-06-2009, 08:33 PM -
Power Steering rack.
By kappasig53 in forum General HelpReplies: 2Last Post: 05-01-2009, 02:37 PM -
manual steering rack?
By Z28J in forum Suspension and HandlingReplies: 4Last Post: 04-11-2007, 09:52 PM -
Power Steering Rack
By chobes in forum Suspension and HandlingReplies: 1Last Post: 02-27-2007, 07:32 AM -
Power Steering Rack Leak
By MLavigne Z/28 in forum General HelpReplies: 1Last Post: 10-24-2006, 05:03 PM
