Results 1 to 11 of 11
    Member 02fbody35th's Avatar
    Feb 2008
    scranton,pa
    2002 camaro 35th anv.
    power steering whine
    hey guys, i just replaced my powersteering pump do to a leak and the new pump is whinning really bad with increased rpms. I properly bled the system and the whine is still their. and i also made sure none of the lines were contacting the engine or anything. what do you think did i just get a bad pump. it seems like a good peice. it is a A-1 cardone reman pump. I dont know. i know i did everything right. what do you guys think?
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    May have to bleed the system again. Is the fluid bubbly?
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    If the fluid is aerated then let it sit for an hour and then drive it again and see if it whines. If the fluid looks great and the pump whines, then yes its probably a bad pump
    Bragg NC
    Met. Sunset Orange
    01 SS
    Ensure you tighetend Both lines, the suctions and the High pressure. If your pulling in air then you will get the wine.
    Like said above check the fluid for aeration and you may have a bad pump. I just went through two pumps on my Dodge ram. Buying Reman pumps are a shot in the dark...
    J
    Pittsburgh
    2008 Hummer H3
    Wink
    Quote Originally Posted by sunsetorangess View Post
    Like said above check the fluid for aeration and you may have a bad pump. I just went through two pumps on my Dodge ram. Buying a Remaned anything is a shot in the dark...
    J
    Fixed..
    Feb 2008
    scranton,pa
    well i checked the lines and they are all tight, and the fluid looks fine no bubbles but the whine is still their, and it was their from the first startup after the install. so it must be the pump. I agree with reman ANYTHING being a shot in the dark but i really dont have a option. i dont think gm has them new anymore, i checked GM Parts Direct and they only have a seal kit available, as well as other part suppliers. so i guess i am stuck with the reman pumps. unless i went with turn one but i cant afford that right now.
    Member DaddySS's Avatar
    Bergen Co. NJ
    2000 Camaro SS Conv.
    Here's the part number for the full pump assy. Note that it's cheaper from the dealer than from the parts house.
    Did you use P/S fluid to fill it and not trans fluid?
    Part Number: 26086074 List Price Core Price Your Price
    PUMP KIT
    $348.36 $0.00 $226.43
    ACDELCO Part # 360011 {#26086074}
    PUMP KIT,P/S
    * Non-stock item--shipping delayed up to 5 business days
    $256.79 $0.00 $256.79
    Feb 2008
    scranton,pa
    huh, thats a first the part is cheaper from the dealer than the warehouse. anyways thanks, i think that is what confused me i saw it listed as a pump kit and assumed that it was a reman kit. anyways i got another reman from advance auto, im gonna give it a shot and if it doesnt work i will just have to pull up the extra cash and get a oem one. thanks
    Nov 2009
    bernaillio county
    navy blue
    2002 camaro ss
    I had the exact same problem with the power steering pump in my 1999 chevy truck. it
    had a whine after a reman. pump was installed. The only thing that stopped it was flushing it out and adding vavoline max power steering fluid.
    Bergen Co. NJ
    Did you use GM power steering fluid when you flushed it?
    Feb 2008
    scranton,pa
    well it turns out it was the pump, replaced it today and it is much better
  1. Power steering Whine
    By theorangeguy in forum General Help
    Last Post: 08-09-2015, 06:37 AM
  2. Help: Whine from Power Steering Pump?
    By BurgerB in forum General Help
    Last Post: 04-24-2013, 02:55 PM
  3. Power Steering Pump Whine
    By kenji226 in forum External Engine
    Last Post: 04-30-2012, 05:06 PM
  4. Question: Power Steering, Manual Rack, Power Steering Pumps-etc
    By TerribleTed in forum General Help
    Last Post: 11-18-2010, 04:37 PM
  5. power steering whine
    By 02fbody35th in forum General Help
    Last Post: 04-30-2010, 01:10 PM
