Results 1 to 20 of 34
    Junior Member silver2002ws6's Avatar
    big spring tx
    2002 trans am
    ms4 cam upgrade ?s
    so i just ordered the ms4 cam package from texas speed and performance and it comes with the vale train uprade springs retainer ex. im planning on getting the ported oil pump and a dyno tune or there any more upgrades that i will need to take in to mind or?
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    You should list mods you already have-like headers...
    2000 Camaro B4C
    the gasket kit that TSP sells, and an oil pick-up tube gasket
    2000 B4C Special Service Package Z28 - Kooks 1&7/8 Stepped 2'' - TSP Torquer V.2 - FAST 92/92 - BDR 4000 Conveter - Xtreme Trans Stage II - Full UMI Suspension - Pacesetter LT's - Comp Drag Shocks - Magnaflow - Cutout - ZO6 MAF - FTP LID - Street Tuned -
    Bay Area
    my highbeams
    Quote Originally Posted by Z28boy2000 View Post
    yep been hearing about that old gasket causing ticking noises
    Quote Originally Posted by silver2002ws6 View Post
    if you're m6 you'll want to get 4.10m gears if you don't have them... a4 a 4000 stall and 3.73 gears...
    big spring tx
    2002 trans am
    yea im replacing all of the gaskets but what is the bore on the head gaskets i noticed texas speed and performance has like three diffrent bore sizes? the only mods i have are pacesetter long tubes lid bellow just put brand new six speed in it and of course a clutch
    Bay Area
    my highbeams
    Why you replacing head gaskets if you aren't swapping heads?
    2000 Camaro B4C
    my thoughts exactly
    big spring tx
    2002 trans am
    im getting them ported and polished and if i dont just so its easier to put the back spring and ret.
    big spring tx
    2002 trans am
    the ms4 will fit with no other modifications like flycutting right?
    Mar 2009
    Arizona
    2002 SS Camaro
    I don't think you need to cut the fly wheel with the ms4 but you diffidently need to get the hardened push rods with any cam upgrade.
    May 2008
    Line Lexington, PA
    2002 z28 camaro
    I would contact Texas Speed about that but you should also check piston to valve clearance with any cam install
    big spring tx
    2002 trans am
    cool thanks so i called texas speed and performance today its going to cost $750 for porting and polishing my 243 heads and another $400 for the dyno tune but it will be all worth it im also uprading to the ported ls6 oil pump
    Bay Area
    my highbeams
    Good luck, a buddy is making 420ish at the wheels w/ that cam and a fast intake. Driven by his friend on street tires he hit high 11's.
    Member 173rdbrandon's Avatar
    A, A
    2000 Trans Am WS6
    You will not have to fly cut the pistons for this camshaft
    big spring tx
    2002 trans am
    sweet thanks guys when i get it in and dynoed i will try and post what i got
    Flycut your pistons.
    Damn MS4's....too fucking big.
    2000 Camaro B4C
    whos got a link to a flycutting visual aid
    Member tg580's Avatar
    niles, mi
    I'm thinking about getting an MS4 also. Why is it too big? What is flycutting a piston and why does it need to be done?
    The cam pushes the limits of piston-to-valve clearance.
    Flycutting opens up small valve reliefs to add clearance.
    That cam also wants a 4000+ stall in an automatic, along with 4.10's.
    It likes 4.56's in the M6.
    All in the set-up. Those large cams can make cars fast, but not without other mods.
  1. ls1 pcv upgrade
    By johnny89345 in forum General Help
    Last Post: 08-10-2011, 07:58 AM
  2. Upgrade Engine, Upgrade Transmission
    By clovenhooves in forum Firebird / WS6
    Last Post: 12-22-2009, 09:07 PM
  3. ls6 upgrade
    By gztoyz in forum External Engine
    Last Post: 07-30-2009, 10:44 AM
  4. next upgrade
    By kthmc33 in forum External Engine
    Last Post: 06-16-2008, 05:18 AM
  5. Simple Upgrade Solutions - Oem Upgrade 2003 Bmw X5
    By Ed Blown Vert in forum Stereo and Electronics
    Last Post: 11-16-2006, 08:18 AM
