12-22-2009, 07:52 PM #1
Upgrade Engine, Upgrade Transmission
If I still own my Trans Am when the engine goes, I'd like to replace it with a LS3 or higher. Would that/should that go with something better than the stock transmission? If it's a stupid question, the reason is a lack of car knowledge.
12-22-2009, 07:59 PM #2
Which transmission are you referring to? A4 or M6?
12-22-2009, 08:03 PM #3
12-22-2009, 08:14 PM #4
If you want to keep the 4l60e, here is a thread with what to upgrade on it. http://www.ls1.com/forums/showthread.php?t=127538
12-22-2009, 08:28 PM #5
Thanks. So other than the transmission cooler (not sure if that technically is part of the tranny), would I need to upgrade parts of the transmission, or would it work fine as is?
12-22-2009, 08:34 PM #6
Heavy Duty double caged 29 element sprag
the Beast sunshell
Transgo HD-2 shift kit
Corvette solenoids
Are you doing it yourself or would you have it built by someone else? If taking it somewhere, most upgrades would include all of the above and then some.
12-22-2009, 08:51 PM #7
I think it's clear I shouldn't be working on a car
I was thinking of buying a transmission, though. With all the changes to be made, I should wait for the engine, if the tranny doesn't first go bad.
12-22-2009, 08:55 PM #8
You could always just throw a cooler on there and see what happens.
I would suggest putting this in the Drivetrain-Transmission-Automatic section.
You will get a lot more, better, responses than mine.
12-22-2009, 09:07 PM #9Slow'er'Ass
- Thornton, CO
I would look into building a tranny.
The stock automatic isn't that stout to begin with. Going to want to beef it up so it doesn't become a problem down the road.
Corvette Transmission Swap - Overdrive Upgrade
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 01-26-2010, 10:10 AM -
Upgrade Transmission?
By [email protected] in forum Manual TransmissionReplies: 6Last Post: 12-10-2008, 05:54 PM -
Engine Upgrade Question
By CorvetteGirl in forum CorvetteReplies: 6Last Post: 06-14-2007, 02:15 AM -
Simple Upgrade Solutions - Oem Upgrade 2003 Bmw X5
By Ed Blown Vert in forum Stereo and ElectronicsReplies: 0Last Post: 11-16-2006, 08:18 AM -
Engine and Transmission Upgrade???
By iceman504 in forum General HelpReplies: 24Last Post: 03-08-2006, 06:12 PM
