Results 1 to 20 of 31
Thread: How Much Can it HOLD?
12-14-2009, 11:26 AM #1Junior Member
- Dec 2009
- Camden, South Carolina
Citrus(burn't) Orange- 2001 Camaro SS
I have a 2001 camaro SS with 111,000 miles. The trans work perfect and shifts like a champ with my diablosport tuner. but i just recently bought a cam(ms3) and heads(P-n-P slp) and i was wondering how much power can you put to the stock trans before it eats shit?
12-14-2009, 11:31 AM #2
Our 4l60-e's are finicky they can tank with just bolt-ons. Are your heads stock just ported and polished, bigger valves? If you clean it out regularly and have a proper cooler that will go a long way to keeping it alive. A friend installed a 228 cam with a 3600 stall and his transmission went out almost a month later (so yah it's a crap shoot)
12-14-2009, 03:08 PM #3
with any stall you NEED a tranny cooler... bigger = better.
there are a few weak points in our trannies you can upgrade =
hd sprag
the Beast sunshell
Transgo shift kit
Corvette solinoids
12-14-2009, 03:23 PM #4Senior Member
- Oct 2008
- Coral Springs, Fl
Would recommend a tranny cooler stock
12-14-2009, 03:46 PM #5Y2K SS (SLP #239)
Completly STOCK heads/bore/stroke/weight
& NOTHING else ---is stock
"NAW-NAW- just a Sunday goto meeting car, my best time is not in the 12's------- any more "
ps: I am not soliticing work as I am retired
>>>info on alignments
http://www.jgruggles.com
12-14-2009, 04:02 PM #6
12-17-2009, 05:19 PM #7
Eh the 4L60E can break stock, I'd personally start saving for a rebuild.
12-17-2009, 08:37 PM #8
12-18-2009, 06:23 AM #9Junior Member
- Dec 2009
yea ive thought about that, so should i go ahead and put a beast sunshell, hd sprag, corvette solinoids, and transgo shift kit?? or just leave it stock and put a cooler on it???
And when i do replace what does it cost to get one rebuilt
12-18-2009, 06:47 AM #10
I went out and got the best of tje best of everything and it cost about $2500 + the stall.
I did beat on the stock tranny daily for a year before it went.
you can pickup the beast sunshell for about $69, transgo shift kit for $200.....cant remember the price of the sprag and pump.
I also got the Raptor R input kit that came with the beast sunshell and sonnex carrier and Hughes race kevlar clutchs and steels, and 5 pin planets
12-19-2009, 12:14 AM #11Junior Member
- Dec 2009
so when you beat on your trans for a year, was it bone stock?
12-19-2009, 04:21 AM #12
Beat on it all you want, but at least put a shift kit in it, and a huge auxiliary cooler, AND SAVE FOR THE FUTURE REBUILD.
I got no problem beating on shit, when i have money waiting to rebuild anything that could go wrong.
12-19-2009, 04:41 AM #13
12-19-2009, 04:43 AM #14
basicly I had the hardest most violent shift possible for a year before it went
12-19-2009, 06:33 AM #15
12-19-2009, 08:13 AM #16
12-20-2009, 06:23 AM #17
You may as well go throught the tranny while it's out. Since you are going to need to pull it to install a lose converter for that MS3 cam anyway.
That MS3 won't work well if at all with a stock converter, and I didn't see a converter on the upgrade list. Converter should be done before a cam,,,,or at the same time.
Chances are good if you chunk the tranny it will take the converter with it, or at the very least pass trash through it to the point where it would need cut open. So why not just go through the tranny now and save some money in the long run.
12-20-2009, 07:12 AM #18
12-20-2009, 07:31 AM #19King 0f n00bz
- Jan 2006
- Shepherd, Michigan
converter + rebuild ..then cam ..the biggest problem with the 4l60e is piss poor flow..causing overheating issues. well that and the stock tunes cause slips for soft shifts.
12-20-2009, 12:12 PM #20
It doent look like you would have much room for a transmisson cooler on the radiator and which cooler are you using?
Battery Hold Down - Hold Down Hold Up
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 06-06-2013, 06:20 PM -
Question: How do they hold up?
By clg82 in forum CorvetteReplies: 4Last Post: 03-28-2010, 01:56 PM -
can it hold?
By 97ws6 in forum Automatic TransmissionReplies: 6Last Post: 01-07-2010, 11:25 AM -
how much will a lt hold
By 94lt1ss in forum NitrousReplies: 4Last Post: 11-21-2007, 10:02 AM -
How well will 4.10's hold up in my car.
By socmninja in forum DrivetrainReplies: 43Last Post: 08-21-2007, 07:57 AM
