Results 1 to 20 of 44
06-17-2007, 02:04 PM #1
How well will 4.10's hold up in my car.
I'd like to know how many M6 drivers out there have swapped in 4.10's and how long you've had them? How well do they put up with hard launches? Who's destroyed a rear with them? What brand make the strongest and quietest set?
06-17-2007, 02:13 PM #2
those gears and a 7.5 rear and a hard launch, it wont last long at all
06-17-2007, 02:13 PM #3
quietest set is prolly GM
06-17-2007, 04:07 PM #4Import Killer
- Sep 2005
- MIchigan
Navy Blue Metallic- 2000 Camaro SS
I have 4.10's for a little over two years....launching is difficult I'am putting LCA's and relocation brackets on this weekend will let you know how it is. I love the gears though still get over 35 mpg on the e-way! mine make noise sometimes is kind of annoying but get used to it.
06-17-2007, 04:41 PM #5
06-17-2007, 05:55 PM #6
damn, who else has had theirs for a while?
06-18-2007, 07:41 AM #7O U 8 1 2
- Nov 1999
- over here...
quietness is all about the install...
4:10's will hold up for a while as long as they are installed right... also it depends on your current mods....if you're going to put in 4:10's replace your possi unit unless it has low miles and also your bearings...
06-18-2007, 09:12 AM #8Senior Member
- Jun 2007
- corona ca
white, white and pewter- Rip99SSA4,74Z28M4,02SSM6
lol and i got an auburn series 3 carrier with bran new bearings
06-18-2007, 09:13 AM #9Senior Member
- Jun 2007
- corona ca
for sale i mean
06-18-2007, 10:20 AM #10
I have 4.10's in my M6 car and they've been fine. They are relatively quiet too.
I don't understand why everyone says 4.10's are so much weaker than 3.42's. The ring gear is bigger, which should put less stress on the pinion gear, since its easier to turn a larger ring gear than a smaller one.
06-18-2007, 11:07 AM #11
That's what I've always wondered!!! Is it just the GM housing that can't support the torque? How many hard lauches at the track have you had Wesman? Also, do you need the install kit's they make? I won't be doing the install, how much is the going rate? Also, do those diff covers/ girdles make *any* difference? Is it just cheap insurance?
06-18-2007, 12:56 PM #12
06-18-2007, 01:01 PM #13
06-18-2007, 01:44 PM #14
06-18-2007, 01:48 PM #15
Lots of hard street driving and 2 launches at the track. Both times I launched between 2000 and 2500RPM, with 285/40/17 tires.
Probably $200-$300 at a shop.Also, do you need the install kit's they make? I won't be doing the install, how much is the going rate?
They help somewhat, because they apply pressure to the bearing caps to keep them from deflecting under stress. However, it still doesn't make the rear bulletproof by any means. Definitely helps though.lso, do those diff covers/ girdles make *any* difference? Is it just cheap insurance?
06-19-2007, 05:55 PM #16Junior Member
- Boca Raton
white- 98 SS
Had mine for about 2 years but only have about 2 or 3 thousand miles on em (garage queen). very rarely hear any gear noise and the change in non-hwy driving was excellent. i recommend it
06-22-2007, 02:11 AM #17
Have had my 4.10s on for almost 2 years. And let me tell you, I've never dropped the clutch above 1500k rpm; still have the stock rear end. Now from a roll, that's a different story...
06-25-2007, 01:54 PM #18
I have an Lid, LS6 intake and full exhaust w/ LT's. most all bolt ons, no cam. Will I be alright w/ 4.10's and Nitto 555's?
06-25-2007, 03:58 PM #19Junior Member
- Jan 2006
- New Orleans, LA
Red- '01 Trans Am WS.6
I've had mine for 5 years and the only issue after 35K miles is a little more gear noise than the stock 3.42's. I drive the car daily; most of the time like a normal person, but hard everytime a Mustang is involved. I have lower control arms, panhard, torque arm, etc. w/ BFG G-Force tires, so the car plants pretty good, which in turn means there really is no need to get into the 2500 or 3000 rpm launch range. The car leaves so much better with 4.10's you don't really have to rev high to make your point. I kinda like it when someone gets that fender length on the launch and then you drive past them like they were in reverse!!
07-08-2007, 07:12 PM #20Junior Member
- Oct 2005
- Reno, NV
Navy Blue Metallic- 2001 Camaro SS
Mine will be 5 years installed next month. 24k miles on them. I pulled the rear to clean and paint it and looked at the gears. They were like new.
I absolutely love the quickness from the 4.10's, and the pulling they give me on the street.
Battery Hold Down - Hold Down Hold Up
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 06-06-2013, 06:20 PM -
Question: How do they hold up?
By clg82 in forum CorvetteReplies: 4Last Post: 03-28-2010, 01:56 PM -
can it hold?
By 97ws6 in forum Automatic TransmissionReplies: 6Last Post: 01-07-2010, 11:25 AM -
How Much Can it HOLD?
By usafshelley in forum Automatic TransmissionReplies: 30Last Post: 12-25-2009, 02:28 PM -
how much will a lt hold
By 94lt1ss in forum NitrousReplies: 4Last Post: 11-21-2007, 10:02 AM
