Results 1 to 18 of 18
Thread: vaccuum issues!!!!!!!!!!!!!!!
03-29-2010, 05:50 PM #1
Ok here is my set up 408 lq9, stage 3 243 heads, cam is a 248/254 .618/.622 113lsa, fast 92/92. 42lb injectors. i have almost no vaccuum. the car is a yr long project and a rather expensive one..... if anyone has any hints as to why i have very little vaccuum let me know cuz im scratching my head
03-29-2010, 06:28 PM #2Senior Member
- Apr 2008
- Madison, WI
because your camshaft is huge
03-29-2010, 07:02 PM #3
ya but plenty ppl run bigger well what do i do to get vaccuum up??
03-29-2010, 11:08 PM #4
Vacuum pump or ditch the booster and go manual brakes...I take it that's why you need more vacuum.
Yes your cam is why you don't have any vacuum
03-29-2010, 11:30 PM #5
even at idle i would think i would atleast at idle.. no?
03-30-2010, 07:58 AM #6
03-30-2010, 10:35 AM #7
03-30-2010, 02:26 PM #8Senior Member
- Feb 2006
- Orange County, NY
You could also go with a hydro boost for the brakes.
03-30-2010, 02:32 PM #9
ya well right now it wont idle and once u get above 3500 rpms it acts fine i know the cam is robbing some vaccuum but im not sure its not losing it thru the intake im gonna put a stock one on and see if i hold vaccuum
03-30-2010, 03:13 PM #10Senior Member
- Feb 2006
- Orange County, NY
Sounds like you have a vacuum leak somewhere.
03-30-2010, 03:22 PM #11
03-30-2010, 03:23 PM #1211 years of bangin gears
- Jan 2009
- North Jersey
I have read in GMHTP that a vacuum booster would be required for vehicles running large cams.
03-30-2010, 05:16 PM #13Senior Member
- Apr 2008
- Madison, WI
To get a big cam to idle better, sometimes you need to crank the ignition timing way up.
03-30-2010, 05:26 PM #14
i have to mention the advancing the timing to my tuner
03-30-2010, 06:00 PM #15
03-30-2010, 06:45 PM #16Member
- Jun 2009
- coon rapids, MN
red- 2000TA
can you reconfigure the air pump to supply vacuum for the brake booster,using a storage tank.
03-30-2010, 07:39 PM #17
I think its Honda that is now using electronic assist brakes and steering, I take it that its electic pumps instead of belt driven... Just a thought
03-30-2010, 07:45 PM #18
i have to consider but first i need to find out if i have a vaccuum leak ?.. il prolly get some vaccuum assistance regardless
DSL Issues
By SMWS6TA in forum Suspension and HandlingReplies: 3Last Post: 05-20-2014, 06:10 AM -
Vaccuum Leak. Manifold hose
By Lunatikgixxer in forum Firebird / WS6Replies: 14Last Post: 08-28-2011, 10:33 AM -
vaccuum modulator or electronic?which is better?
By Leeroyws6 in forum Automatic TransmissionReplies: 2Last Post: 10-18-2010, 05:50 AM -
Not getting enough vaccuum to operate heater controls
By Shaun Beil in forum General HelpReplies: 4Last Post: 07-28-2007, 01:41 PM -
the car is having issues
By formula1804 in forum Firebird / WS6Replies: 2Last Post: 01-12-2007, 08:36 AM
