Results 1 to 15 of 15
Thread: Vaccuum Leak. Manifold hose
08-27-2011, 05:43 PM #1Senior Member
- Mar 2010
- St Pete, FL
Bat mobile black- 2000 Trans am WS6 M6
Where does this hose go? Its coming from the back of the manifold and i dont know where it connects to back there..
08-27-2011, 06:14 PM #2Senior Member
- Jan 2010
- texas
silver- 2000 formula
that is either the line to the AIR........or to the HVAC........if it leads to the pass side.........its HVAC
08-27-2011, 06:29 PM #3Senior Member
- Mar 2010
- St Pete, FL
nooo where does the other end connect to? that side is connected to the back of the manifold
08-27-2011, 07:00 PM #4Senior Member
- Jan 2010
- texas
that T you see in the pic......with a black rubber angled nipple......and a hard line.......is the line for the AIR....the other end of that T goes to the HVAC nipple that is in your pic
08-27-2011, 07:04 PM #5Senior Member
- Jan 2010
- texas
oops..........unless it is the other end of the HVAC line that connects to the the nipple somewhere by the HVAC on the firewall........so which is it....the firewall side or the back of the manifold side?...........ah silly me..........re read your post.......i will get a pic of the firewall side for ya tommorrow
08-27-2011, 07:39 PM #6Senior Member
- Jan 2010
- texas
my flash worked pretty good
08-27-2011, 07:39 PM #7Senior Member
- Jan 2010
- texas
08-27-2011, 11:17 PM #8Senior Member
- Mar 2010
- St Pete, FL
Thanks man! i will check it out in the AM. Thank you
08-28-2011, 09:20 AM #9
i just checked the back of my intake it is a 98 with the ls1 intake still on it and i only felt the vacuum line for the hvac i didnt feel another one for the air system. Is there a difference in the years for the ls1 intake? Also i removed the air system when i did headers on it.
08-28-2011, 09:20 AM #10Senior Member
- Mar 2010
- St Pete, FL
Ok that still isnt what im talking about, that part is fine and connected.. Its the small hose that looks similar to that but runs out of the back of the intake manifold... Where does this end connect to?
08-28-2011, 10:19 AM #11Senior Member
- Jan 2010
- texas
that end connects to the AIR....let me find a pic..........
08-28-2011, 10:26 AM #12Senior Member
- Jan 2010
- texas
that blue weatherpack thingy is the AIR selenoid......there are 2 nipples on it......one goes to the hockey puck lookin thingy right behind it(not shown in pic).........the other goes to that hard line in the pic
08-28-2011, 10:28 AM #13Senior Member
- Jan 2010
- texas
there are only 2 lines running off of that T......either AIR or HVAC
08-28-2011, 10:30 AM #14Senior Member
- Jan 2010
- texas
this is the hockey puck thingy....it bolts on the back of the head with the bracket..........you can see the other hard line on it
08-28-2011, 10:33 AM #15Senior Member
- Mar 2010
- St Pete, FL
i found it! thanks for the help. hopefully it solves my high idle problem
Hose above the inake manifold
By edrvsqz1980 in forum Firebird / WS6Replies: 3Last Post: 02-03-2017, 11:18 PM -
Possible Vacuum Leak with BBK SSI manifold...
By jfl330 in forum External EngineReplies: 5Last Post: 06-05-2011, 04:45 PM -
vaccuum modulator or electronic?which is better?
By Leeroyws6 in forum Automatic TransmissionReplies: 2Last Post: 10-18-2010, 05:50 AM -
Help: vaccuum issues!!!!!!!!!!!!!!!
By lancesT/A in forum Internal EngineReplies: 17Last Post: 03-30-2010, 07:45 PM -
Intake Manifold LEAK!!
By 96t/a in forum LT1Replies: 3Last Post: 12-12-2007, 06:40 PM
