07-28-2007, 06:24 AM #1Junior Member
- Jul 2007
- Ellijay Ga
Blue- 1079 Camaro
Not getting enough vaccuum to operate heater controls
I have a 1979 camaro and wasnt getting enough vacuum to operate my heater controls. I dont see a vacuum tank anywhere and was wondering if my camaro should have one. The vacuum lines seem ok. Any suggestions would be appreciated. Thanks!
07-28-2007, 06:31 AM #2Simpsons Did it!!
- Mar 2007
- Minnesota
83 Z28 new project- 98 Formula WS7-sold:(
You may have them hooked up to the wrong port off the carb. Do you have a big cam?
TSP Torquer V2 cam, ported heads,fast 90/90 combo, LT's, 3400 stall, magnaflow CB, most other bolt ons, full suspension, t-top and HID conversion
422 RWHP, 384TQ
07-28-2007, 06:38 AM #3Junior Member
- Jul 2007
- Ellijay Ga
Blue- 1079 Camaro
I have a street cam...nothing too radical and i have it hooked to a quadrajet carb on the bottom where the highest vacuum is. The brakes and all work fine so it seems there is enough vacuum. There is just a teeny line coming from the firewall and i hooked it up but it didnt do any good. Should i replace all the lines? That will be a job...but i may have to...i guess i need a vacuum pump to test it and see if it holds a vacuum. Is there a certain place on my carb i need to hook up to? I had a Holley 750 but now run a quadrajet so i get better mileage.
07-28-2007, 07:22 AM #4Simpsons Did it!!
- Mar 2007
- Minnesota
I like the idea of the vacuum pump to see if it holds pressure. If I recall, it has hard plastic lines under the dash for the controls, its possible for those to crack or simply cound have came off the control. The vacuum hose is attached where I would have put it, you could try to put on another one of the smaller ports just for kicks.
07-28-2007, 01:41 PM #5
You should also start with a vacuum gauge and see what you're pulling.
Question: How do I operate the disc changer in my trunk?
By ldurham in forum Stereo and ElectronicsReplies: 2Last Post: 01-26-2012, 05:22 AM -
Question: Are 4th gens expensive to operate @ own!!
By denegrader in forum General HelpReplies: 12Last Post: 04-23-2011, 09:44 PM -
Help: vaccuum issues!!!!!!!!!!!!!!!
By lancesT/A in forum Internal EngineReplies: 17Last Post: 03-30-2010, 07:45 PM -
ac heater controls for a 2001 firebird
By truckguy in forum Parts Wanted / TradeReplies: 2Last Post: 01-18-2007, 01:17 PM -
Heater Controls - Are these electronic
By zeeboid in forum Stereo and ElectronicsReplies: 1Last Post: 01-30-2006, 12:11 PM
