Results 1 to 13 of 13
Thread: Tire height
03-09-2010, 08:00 PM #1
Tire height
Everyones always asking about the widest tire that you can fit, what about the tallest on stock height? Thanks
03-10-2010, 07:25 PM #2
20 views...no responses
03-10-2010, 08:26 PM #3
Depending on the wheel DIA. I wound'nt go anything over a 60..
03-10-2010, 08:41 PM #4
60 in what respect? How about in inches cause I don't know what rim size I'm going with
03-10-2010, 08:52 PM #5
lol 60 is the side wall height in millimeters.. Such as example: (45-50-55-60) hence a "60" is all the taller I'd go on a 16 inch wheel for instance.. Anything taller would likely rub.. I don't run 17-18-19 inch wheels on anything so maybe someone else will chime in here. The first number on a tire is tread width, second as stated above is wall height, and the 3rd is the size of wheel the tire will fit..
03-10-2010, 09:00 PM #6
These are my new ZR summer tires for example. 265 is their width, 45 is their height, and the last is for the wheel size.
03-10-2010, 09:02 PM #7
03-10-2010, 09:06 PM #8
03-10-2010, 09:10 PM #9
Nope.. they are 30mm wider than factory, 10 mm shorter, and mine are $700.00 per set and zr rated. Factory 16 tires were not.. I don't use "tire rack" I special order mine from a local supplier. This will shave 2nd gear but will see torque to the road gains across the board..
03-10-2010, 09:25 PM #10
03-10-2010, 09:27 PM #11
My tires are NOT street legal...
03-10-2010, 09:30 PM #12
03-13-2010, 06:19 PM #13
Ride height change with bigger wheels/tire
By finkle745 in forum Wheels and TiresReplies: 17Last Post: 08-15-2016, 11:59 AM -
'will this tire fit?' thread: sidewall height edition.
By justinmc978 in forum Wheels and TiresReplies: 11Last Post: 10-10-2011, 07:12 AM -
Stock tire height?
By AKIRA in forum Wheels and TiresReplies: 5Last Post: 03-12-2009, 04:56 PM -
tire width and height
By Chevyfan99 in forum Wheels and TiresReplies: 3Last Post: 07-28-2008, 06:59 PM -
tire height?
By TedsB4Csled in forum General HelpReplies: 1Last Post: 04-16-2008, 12:28 PM
