    WA
    tire width and height
    i would like to get some 265 or 255 wide tires for the back of my camaro. the problem is i want them to be the same height as the tires i have now which are 245/50 ZR16. does anyone know how to fill in the blank 265/(?) ZR16..... or 255/(?) ZR16?
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    google tire size calculator, theres a result with like, 1010tire in the name, something like that. its really good
    The thing to remember is that with a 245/50, that means your height is 50% of your width, 245. so if you are upping the width to a 265, you need to lower the percentage to probably 40% to keep the same hieght. so 265/40. But that first number, 245/255/265, etc, is the distance in mm. a 265 is only 20mm wider than a 245, so even if you stuck with a 265/50, your height would only increase 10mm.
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    Eugenio_SS
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    in 16", there just isn't any other option. you can go to the 255/50-16 and get the extra 10mm (less than 1/2") wider tire. what you should do is look for the same size tire that offers the most tread width. the first number (245) is from sidewall to sidewall. it's not the actual tread width.
  1. Rim Width vs. Tire Width and Performance
    By Naaman in forum Wheels and Tires
    Last Post: 02-11-2018, 06:52 AM
  2. Question: Tire width options
    By dethinboots in forum Wheels and Tires
    Last Post: 01-06-2013, 04:16 PM
  3. max wheel width and tire width for C5?
    By MachWon in forum Corvette
    Last Post: 04-17-2010, 03:38 PM
  4. Question: Tire Width Concerns
    By Cobra Killer in forum Wheels and Tires
    Last Post: 02-03-2010, 12:03 PM
  5. max tire width in front for DD
    By swisscheese in forum Wheels and Tires
    Last Post: 11-12-2008, 11:07 AM
