    lmpounded SandmanWs7's Avatar
    Dallas, Texas
    2007 CTS-V
    Tranny or Clutch???
    Every once on awhile I have a REALLY hard time putting it in 1st,2nd or reverse. I mean I can put all my weight into it and it doesnt go into gear. This sux when I am on the road at a light, cause I then cant put it into gear right away. I will usually have to slam it into 3rd then 4th and like that I can then put it in 1st. WTF?!?!?
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Sounds like a clutch issue.
    Typically, anytime you have trouble engaging gears while the car is stopped, its a clutch system release issue. It could be the master cylinder, slave cylinder, or even a pilot bearing.
    Check your clutch fluid and look for leaks between the engine and trans bellhousing. There is a small square opening in the bottom of the bellhousing, its its dripping fluid from there, its probably your slave cylinder.
    It may also be a good idea to change the fluid. Pick up some DOT4 brake fluid and bleed the system until the fluid comes out clear.
    Dallas, Texas
    2007 CTS-V
    Quote Originally Posted by Wesman View Post
    I do need to change the motor oil, so I will check for leaks in that area.
    How do you bleed the system? link?
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by SandmanWs7 View Post
    Here you go:
    http://www.installuniversity.com/ins...r_cylinder.htm
    See step number 26.
  1. clutch / tranny
    By Big D Squared in forum Manual Transmission
    Last Post: 07-14-2012, 09:33 AM
  2. Clutch or tranny??
    By youngun67 in forum General Help
    Last Post: 01-31-2011, 06:06 PM
  3. Clutch, tranny, or what?
    By Ironwolf in forum Manual Transmission
    Last Post: 09-30-2009, 10:48 PM
  4. Tranny, Clutch, or Clutch Hydraulic System?
    By IZNUTHN in forum Manual Transmission
    Last Post: 07-31-2007, 06:13 PM
  5. clutch and tranny problems
    By lmt0705 in forum Manual Transmission
    Last Post: 01-12-2006, 10:26 PM
