Thread: Cam sensor HELP
    Oakley Ca. USA
    1973 240z LS1/t56
    Cam sensor HELP
    When I pulled my motor I for got about the cam sensor plug and broke 2 of the wires . Can anyone tell me which wire goes to which pin or if it matters .The red wire is still in the plug. The pink/b and the brown/w that broke . The motor is from a 1999 Camaro . Thanks
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Pink/BLK 632 goes to "B" (GROUND)
    BROWN/WHITE 633 goes to "A"
    RED 631 goes to "C" (POWER)
    Build in progress...
    Oakley Ca. USA
    1973 240z LS1/t56
    Man thank you so much . That helps me out !!!!! Now I can plug it in and start it
    Thanks a million
    Florida
    1999 TA WS.6
    No problem.
  1. Help: 02 sensor bank 1 sensor 1-Is this drivers side or Passenger
    By cballweg in forum General Help
    Last Post: 01-15-2012, 11:44 AM
  2. Question: Reading trans temp stock sensor vs aftermarket sensor in pan
    By senicalj4579 in forum Computer & Tuning
    Last Post: 03-29-2011, 08:41 AM
  3. Knock Sensor/Oil Pressure Sensor Issue
    By Slow '99 in forum External Engine
    Last Post: 04-04-2007, 09:28 AM
