Results 1 to 15 of 15
Thread: LT1 and LT4 Knock sensor
01-11-2010, 01:42 PM #1
I was wondering if antone knew if there is a differance between the lt1 and lt4 knock sensor? I have the lt4 knock modual so thats not what I am talking about. I am asking about the actuall sensor on the motor. Thanks guys
01-15-2010, 12:04 PM #2Member
- Feb 2008
- Russellville, MO
I don't think that there is any difference.
01-16-2010, 07:01 PM #3
The LT4 is less sensitive then the LT1.
01-17-2010, 09:11 AM #4Member
- Feb 2008
- Russellville, MO
The knock module is less sensitive, he is asking about the sensor that scews into the drivers side head. I believe that they are the same part. Otherwise wouldn't you have to change both the module and the senor?
01-17-2010, 10:40 AM #5
^You would be correct.
01-18-2010, 11:33 AM #6
k that is what I thought Thanks for the intel
01-23-2010, 04:29 PM #7Junior Member
- Jun 2009
- ohio
pewter- 95
so in my rebuild i should go to lt4 module and sensor
01-23-2010, 06:53 PM #8Member
- Oct 2009
- Las Vegas
- 2000 ss/1994 z28/1979 z28
01-24-2010, 12:53 AM #9
An LT4 knock module wont make a damn bit of difference if you have no false knock. However they are cheap insurance if you will have noisier than stock components under the hood such as headers, aftermarket valvetrain, etc. Those components dont by any means guarantee you'll see false knock though.
01-24-2010, 08:38 AM #10Member
- Oct 2009
- Las Vegas
02-07-2010, 07:32 AM #11Junior Member
- Jun 2009
- ohio
pewter- 95
cant a tunner make it pickup less knock
02-07-2010, 08:15 PM #12
yes but if you just want to bolt on LT headers and ory and not spend 150 bucks more on a tune then it helps make sure you don't get the false knock.
Pulled the spark plugs on mine today. After doing LT headers, ory pipe, egr delete over a year ago, they are perfect after a year of running on stock tune.
02-08-2010, 02:47 AM #13Junior Member
- Apr 2009
- tn
So if your getting a tune, is it better to have the lt1 module made less sensitive or just swap to the lt4 module or swap to the lt4 and have it made less sensitive?
02-08-2010, 02:49 AM #14Junior Member
- Apr 2009
- tn
02-08-2010, 11:33 AM #15
I said to help make sure you don't have false knocks. In other word when you add headers, roller rockers and stuff to the engine, sometime these parts cause extra noises in the engine compartment that can be picked up by the knock sensor and read by the knock modual as knock when they are not. The lt4 knock modual is less sensitive to report these sounds that the knock sensor picks up. When the knock modual reads these sounds as a knock then it tells the PCM and the PCM pulls timing out to try and reduce the knock. It's just a very small helping aid to not have problems. You can run the LT1 modual and you may never have a false knock. Some times guys have no problems at all. If you do have problems you can use this to help solve the problem insted of a tune. My thing was that I was going to be changing the engine anyway so why waist money on a tune when it would just have to be redone again and cost me money I don't need to spend at that time. But I get to work out any bugs in the exhaust and have it ready for the engine swap.
knock sensor code with new knock sensors?
By zaaronz in forum General HelpReplies: 13Last Post: 02-27-2011, 06:26 AM -
Knock Sensor ?
By Jheath5193 in forum General HelpReplies: 1Last Post: 01-20-2011, 02:31 PM -
Which knock sensor do I need?
By SMWS6TA in forum General HelpReplies: 7Last Post: 12-27-2010, 10:09 PM -
will bad knock sensor knock down hp
By zaaronz in forum General HelpReplies: 11Last Post: 10-14-2010, 04:49 PM -
Knock Sensor/Oil Pressure Sensor Issue
By Slow '99 in forum External EngineReplies: 1Last Post: 04-04-2007, 08:28 AM
