    canada
    98 camaro
    Question engine knock sensor
    Where do I find the knock sensor? How do I replace it?
    Thanks
    Remove the intake manifold, and there is a valley cover between the heads. The knock sensors are located down inside that valley cover.
    Painted manta stripe
    Dec 2009
    Calgary, Canada
    87 Monte SS
    Yes they are under the intake plenum, pretty straight forward job, 9 time out of 10 the rear one will have rust and corrosion around it, as for some reason water gets in around it, make sure you buy new a new knock sensor harness as well, as it gets corroded also, it's very cheap and readily available from GM also, use GM sensors also, saves headaches sometimes.
    Dec 2009
    Florida
    Artic white
    2001 corvette
    What is the purpose of knock sensor
    Quote Originally Posted by Sic vett View Post
    detects knock or pre-detonation and pulls timing
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Use some small (skinny) plyers to remove them. Having an asortment of plyers helps alot.
    About halfway down, there are some nice pictures on exactly this.
    http://www.ls1howto.com/index.php?article=18
    Member joedude02's Avatar
    Goose Creek, SC
    Victory Red
    2002 T/A WS6 A4
    don't mean to thread jack, but is it common for the knock sensors to act up from time to time? my car seems to have a good day and a bad day if you know what i mean. i can feel the timing retard on the bad days.
    Goose Creek, SC
    Victory Red
    2002 T/A WS6 A4
    ttt
    not to my knowledge....do you wash the engine with water? That's the number 1 killer of knock sensors. You have to first log the car to make sure you're actually getting timing pulled then you need to verify that it's false knock and not real knock. Couple things can cause knock.....too lean, too much timing, build up of carbon ect. ect. The first step is to log it though and see if you're actually getting knock retard then go from there.
    Goose Creek, SC
    Victory Red
    2002 T/A WS6 A4
    i have to admit that i do rinse the engine off with water after engine brite cleaning. guess i need to replace them. 70k and i just started stompin on it.
    NC
    SOM
    1998 T.A.
    Quote Originally Posted by joedude02 View Post
    I would verify the pcm is pulling timing due to false knock before I go through that trouble......
    Greene, Iowa
    99 Chevrolet Camaro Z-28
    not to high jack but im having issues with my knock sensiors too...mine is bank 2 low input...i have rinsed my engine off in the past. but its been a good 6months since i last washed it and got this code. at first it would go on and off intermittently, but now its constantly on, and gas mileage is suffereing for it....so i take it my ecu is throwing a ton of timing at it compensating for the low input??
  1. Piston Slap or Engine Knock Sensor Bad
    By ramontgo in forum Internal Engine
    Last Post: 04-23-2012, 04:51 PM
  2. knock sensor code with new knock sensors?
    By zaaronz in forum General Help
    Last Post: 02-27-2011, 06:26 AM
  3. Knock Sensor check engine light....
    By eddielb in forum Western Members
    Last Post: 04-06-2008, 09:20 AM
  4. Knock Sensor/Oil Pressure Sensor Issue
    By Slow '99 in forum External Engine
    Last Post: 04-04-2007, 08:28 AM
  5. knock sensor engine light
    By kodiak120 in forum General Help
    Last Post: 01-10-2006, 10:17 PM
