Results 1 to 13 of 13
Thread: knock sensor engine light
01-10-2006, 11:18 AM #1Junior Member
- Dec 2005
- Austin, TX
pewter- 2001 Camaro SS
I had a check engine light come on recently so i took my 01 SS to the dealer and they said it was a misc. code. Found out i had a small coolant leak from the water pump and the water pump seal was bad. Fixed the leak. Cleared the code and now its on again claiming its the engine knock sensor. Mechanic stated it might be caused by coolant leaking on the dristributor prior to leak fix. I've noticed some slight knocked but it seems random. Some days good some days a little rough. At idle its smooth.
Any suggestions? Or keep going around in circles with this code.
Thanks
01-10-2006, 11:28 AM #2The RookieGuest
Do you have an after market filter?? Have you cleaned and oiled it lately?
01-10-2006, 12:41 PM #3Junior Member
- San Jose CA
White- 99 Z28
Replace the knock sensor. If any water gets under your intake manifold they will get water in them and rust. This can happen from washing your engine.
01-10-2006, 12:59 PM #4Junior Member
- Dec 2005
- Austin, TX
I do have a K&N filter which prob needs cleaning. I will try that.
01-10-2006, 02:38 PM #5They fixed that issue with different sensors in 2001, same year as his car. It's not false knock from that
Originally Posted by IRACE2
01-10-2006, 02:39 PM #6
When is the last time you changed the fuel filter? Ran any crappy Gas Lately?
01-10-2006, 02:44 PM #7Junior Member
- Dec 2005
- Austin, TX
fuel filter was changed 15k ago.......running shell 93 octane
01-10-2006, 02:46 PM #8Junior Member
- Dec 2005
- Austin, TX
I don't think its a false knock....it does knock but not all the time. I'm trying to figure out why its inconsistent. One trip and its great then the next its knocking up a hill in 3rd gear......
01-10-2006, 03:00 PM #9masterblasterGuest
I had a similar prob with mine, replaced nasty old K&N with stock filter, changed fuel filter, and ONLY run shell 93 and no more knocking/pinging for awhile. It has started pinging a bit lately, maybe got a bad tank of gas. Are these f'ing cars gas sensitive or what???
01-10-2006, 04:37 PM #10Junior Member
- Dec 2005
- Austin, TX
Put a stock filter in and going to clean and oil the K&N. Going back to have the code read tomorrow and then reset. I'll check to make sure when i had my last fuel filter...just to make sure i didn't skip it at the 30k(well 35k) maintenence. I have 50k on it now.
01-10-2006, 05:00 PM #11Junior Member
- Dec 2005
- Austin, TX
fuel filter done 17k ago......i could replace that but i don't see it solving the problem.
01-10-2006, 09:58 PM #12The RookieGuestKodiac, What I was trying to say is if you recently cleaned your filter, the oil may have contaminated your MAF. I had a knock sensor go off a while back, I heard abunch of different things from different folks. But I was planning on replacing my knock sensors until Sarge asked if I had recently cleaned my K&N. Which I had. What happened is I put too much oil on it and it contaminated the small electrical wires on my MAF. Once I recleaned the Filter (to get the excess oil off of it), Cleaned my MAF with electrical cleaner, killed the battery by leaving the key on with the lights and radio on for 2 hours to completely kill it. I then charged the baterry and ran it through 3 heat cycles. The light went out and it started running fine again. no problems sense, and man it saved a lot of work. THANKS SARGE!
Originally Posted by kodiak120
01-10-2006, 10:17 PM #13Junior Member
- Dec 2005
- Austin, TX
I see.....no i hadn't cleaned it yet. Thanks
Every other time i drive it seems as though when in low gear ie 3rd going 40 or skip shifting which i don't normally use in makes a gum ball like knocking sound (not sure of the universal knocking definition). I noticed it some before having the coolant leak fixed....should i be concerned for something major here? Or is it most likely a fuel/air/tuning problem?
Piston Slap or Engine Knock Sensor Bad
By ramontgo in forum Internal EngineReplies: 0Last Post: 04-23-2012, 04:51 PM -
knock sensor code with new knock sensors?
By zaaronz in forum General HelpReplies: 13Last Post: 02-27-2011, 06:26 AM -
engine knock sensor
By binnie2424 in forum External EngineReplies: 11Last Post: 01-01-2010, 09:38 AM -
Knock Sensor check engine light....
By eddielb in forum Western MembersReplies: 7Last Post: 04-06-2008, 09:20 AM -
Engine coolant light sensor.... worth replacing?
By JehalinTA in forum General HelpReplies: 12Last Post: 06-29-2007, 01:53 PM
