Results 1 to 13 of 13
    houston
    Navy Blue
    ls1 trans am
    Engine coolant light sensor.... worth replacing?
    Hey guys,
    My engine coolant light keeps coming on and I know that the coolant is full in both the reservoir and the radiator. When the car was under warranty I took the car in like 6 times for the same light and they never fixed the problem. Is it worth buying a new after market sensor or do you guys just unplug it or ignore the light and check the fluid often? Thanks guys
    Senior Member
    Jacksonville, FL
    They go bad all the time - don't understand why they had such a problem solving it - a new GM sensor should've worked? Anyway, a lot of people just disconnect it - my car doesn't even have one, along with all the others from 00-02.
    LoudMouth SStriker's Avatar
    Westminster/Sykesville, Maryland
    2000 Trans Am
    Anyone know if you can trick the Computer into thinking its fine? With either a resister or jumping pins at the connector? How does the sensor work?
    Senior Member Wheeler99WS6's Avatar
    indiana
    black, 05 Roush
    black, 99 T/A WS.6
    I too would like to know of an easy way to get that damn light to turn off. Drives me crazy.
    Senior Member
    Jacksonville, FL
    Just disconnect it and the light will stay off - zip tie it out of the way.
    Jun 2006
    irving
    candy red
    98 Camaro Z28
    I replaced mine, it was only $41.00 for me since I was wearing my pep boys shirt at the time I used to work. I think its worth replacing, because it really works when ur low on coolant.
    houston
    Navy Blue
    ls1 trans am
    Its $41.00 at pepboys for an aftermarket sensor?
    Jun 2006
    irving
    candy red
    98 Camaro Z28
    No, it was $41.00 at the dealership, they have an account with pepboys, sorry I didnt clarify that earlier.
    with a LS1 2MuchFun's Avatar
    Dayton, Ohio
    2005 Cadillac CTS-V
    i go to a tech school, if i wear my lab shirt into the local chevy dealer, i get 10% off!! thing is, i buy almost nothing at the stealership, i just had to buy a window seal cuz noone else had one........
    Senior Member
    Jacksonville, FL
    A friend of mine last name is Sears - he always seems to get a discount if he orders over the phone and has them set the part aside to pick up.
    indiana
    black, 05 Roush
    black, 99 T/A WS.6
    Where is this plug for that sensor located?
    Senior Member
    Jacksonville, FL
    The sensor is on the radiator, a few inches below the radiator cap.
    indiana
    black, 05 Roush
    black, 99 T/A WS.6
    consider mine unplugged then. Appreciate the help.
    1999 T/A WS6 Black -------SOLD
    05 mustang Roush sport;
    DOB manifold, m122 SC, 47lb injectors, gt500 TB, roush TVS CAI, Detroit rocker SC grind camshafts, Mac LTs, off road x, roush off road mufflers, roush short throw shifter, kenne bell BAP, Brenspeed 93 octane tune. 479rwhp 436ftlbs SAE.
  1. Help: engine coolant sensor!!!
    By pmolina0436 in forum GTO
    Last Post: 01-05-2011, 06:22 PM
  2. Knock Sensor check engine light....
    By eddielb in forum Western Members
    Last Post: 04-06-2008, 09:20 AM
  3. Engine Coolant Low - Warning Light
    By Mike's TA in forum General Help
    Last Post: 09-20-2007, 07:24 PM
  4. Coolant light...coolant level full.
    By SR71 in forum General Help
    Last Post: 01-08-2007, 09:35 AM
  5. knock sensor engine light
    By kodiak120 in forum General Help
    Last Post: 01-10-2006, 10:17 PM
