Results 1 to 20 of 23
12-06-2009, 06:29 PM #1BLKHWK
- Oct 2008
- New Brunswick Canada
Black- BLK TA modded 12.2@113mph
3:73 gears.questions on 3 upgrades
My 99 TA is running 13.5 to 13.65 at about 104 to 105 mph right now bone stock
What will it do for me on time and mph It's an auto with 3:23 gears right now,.
I am never going to do more than 10 to 20 passes a year but I love going 2 or 3 times a year but this is more of a daily driver so should I also put in a stall I was thinking TCI3200 ,3:73 gears a lid and maybe a frost tune like I see people doing on here or kill the stall and put a mild cam or just grears and a lid
I want to feel a big enough difference but not kill my wallet. I love my wallet when it has a little green$ in it lol
Sorry for the long thread
12-09-2009, 11:21 AM #2Member
- Mar 2007
- Gainesville, VA
Lid, gears and stall. If you do a cam you will need a stall to get it to launch. IMO a tune is not worth the $$$ until you do at least headers.
12-09-2009, 10:37 PM #3
After a stall and gears you need a tune for sure
12-10-2009, 04:25 AM #4Member
- Mar 2007
- Gainesville, VA
12-10-2009, 04:40 AM #5
I think you could get by with anything under 3000 but anything higher then that you'd want one for sure.
12-10-2009, 02:36 PM #6
I thought when someone does gears you gotta tune the car for the speedo and the computer to tell the trany when to shift.
12-10-2009, 02:43 PM #7
yea you do I remember when I first put my 4.10s in my z28 and driving it home on the interstate it my speedo said like 95 and people were passing me like I just sitting still lol.
12-10-2009, 06:02 PM #8BLKHWK
- Oct 2008
Cheers
Thanks people much appreciated. A stall scares me on daily driving so gears an intake and a tune I think thos year
12-10-2009, 07:12 PM #9
Getting a stall for and a4 would be one of the best mods for your car if it's a bolt on car just ask 1986camarojoe his 99 z with bolt ons with that 3400 stall threw you back into the seat. IMO I'd go for the stall also
12-10-2009, 10:04 PM #10
After putting the 373s in my car without a tune id hit the rev limiter at WOT, pretty sure the shift points need adjustment
12-11-2009, 01:26 PM #11
12-13-2009, 01:32 PM #12
A tune will benefit a stock car,,,especially the automatics. Did mine.
Besides, with the mods you plan, like gears and such, I wouldn't hesitate for a tune.
A mail order from Frost would do the trick and it's cheap enough to not even bother questioning why not.......
A stall generally requires a tune. The computer will sense the transmission slipping and set a misfire code. At the very least the misfire sensitivity will need to be turned down a bit,,,some even turn it off completely if it continues to give codes.
Sometimes shift points need to be adjusted a bit as well when a converter is installed. I didn't find this necessary with mine, but some do.
With a gear change,,,,the speedo will need calibrated at the very least.
I would do a converter before I bothered with a gear,,,,especially before spending any money on that 7.5.
With a good converter you shouldn't have to worry about daily driving. My mileage was only affected 2 mpg around town, and highway isn't affected at all of course, as the converter locks just like the stocker.
My vote would be for a converter, some headers if not already on there, and a mail order tune from Frost.
12-13-2009, 01:44 PM #13
12-13-2009, 02:38 PM #14
12-13-2009, 02:39 PM #15
12-13-2009, 03:38 PM #16
yes the converter will throw you back in your seat just dont go to big or you will need a tune and an auxiliary cooler for the torque cooler . If you just want a sicker deeper sounding exhaust with simmilar gains get some long tube headers and bam you just woke up your cars exhaust and it sounds sick with similar gains with the lid and any other bolt ons you baught it just makes the horsepower go up with every other mod you do also fyi
12-13-2009, 03:40 PM #17
12-13-2009, 05:20 PM #18BLKHWK
- Oct 2008
Yes!!!!!
I;m in where is the best place to buy a stall and 3000 or 3200
12-13-2009, 05:37 PM #19
yank, vigilante, circle-d
12-13-2009, 05:38 PM #20
Try these site sponsors. Give them a call Monday.
http://www.performabuilt.com/convertermain.html
http://www.lmperformance.com/t/73-2/1.html
http://www.neweraperformanceparts.co...42&NID=6694155
Start there. Some converters are better then others, just like clutch's, you get what you pay for.
questions about frame/chassis upgrades
By Bad Bird in forum General HelpReplies: 20Last Post: 03-09-2014, 04:21 AM -
Upgrading intake on a stock LS1, questions, questions.......
By mrbvlo in forum External EngineReplies: 6Last Post: 12-30-2011, 11:40 AM -
Help: about to change my plastic gears for brass gears
By edrvsqz1980 in forum General HelpReplies: 17Last Post: 07-18-2009, 05:09 PM -
I want to change my gears, have two questions.
By Cronex in forum DrivetrainReplies: 13Last Post: 03-31-2008, 08:08 AM -
3:73 gears, 3:42 gears, clutch, flywheel, plug wires
By ls1hater in forum Parts For Sale / TradeReplies: 4Last Post: 08-16-2005, 06:15 PM
